You have the thermostat on 70, what are you an Eskimo? The compressor has to have a chance to cycle. Only suggestion I have at the moment, is try to step down in temp. Start with 80, once the compressor cycles once or twice, then 78, wait again on things to catch up, then 76, and so on. Also close blinds and curtains in the trailer to help with cooling. Of course if it wasn't freezing up before in the same circumstances, and it is now, it has a problem, and will need to be serviced.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
