Closed Thread
Old 04-24-2012, 11:07 AM   #201
Herk7769's Avatar
Originally Posted by burger View Post
Hi Wildcat Chris,
I have a 2006 Wildcat 32QBSS I purchased new and the side walls are delaminating. I contacted Rod Batts and he said too bad its not under warranty and FR will not do anything. I have heard from others FR repaired their delamination issues out of warranty. Why won't they fix mine? What can I do? I paid $35K new for this thing. It looks like hell and every time I go camping people notice it. Is this the kind of advertising Forest River wants?
Eric
So let me get this straight.
6 year old camper.
Delamination noticed this year
No photos of roof or seams to show it has been well maintained
No reciepts to show roof membrane maintenance
Yet somehow this is all FR's fault
First post on the forum is to flame FR for not fixing your camper for free
Did I get all that right?
Just want to be fair.
Let me know how this all turns out.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 04-24-2012, 11:27 AM   #202
herk7769
No it did not just start. The delamination has been going on since 2007 and I have tried several times to get it addressed by FR, dealer, and BBB.
My trailer has been well maintained and inspected everytime I wash and wax it, which by the way is monthly.
My first post on this site because I was searching for help.
Did you get it right? No you are clueless. I am looking for help here, not trying to start anything.
Yes I do consider it FR's fault, if you do some research you would know this is a problem and not just caused by water damage.
I believe the thread started was to help people.
Sorry if I ruffled your feathers, but don't treat me like I have no clue what I am talking about. I have been in aviation maintenance for over 30 years and know a little about maintaining something.
burger is offline
Old 04-24-2012, 01:29 PM   #203
Herk7769's Avatar
I am sorry, I was touchy this morning.
7 phone calls to judge elections today; starting last night at 9PM.
Good luck with your attempt at resolution.
I still feel you will have an uphill fight on your hands.
Unusual that I get that testy with a post.
I should report myself.
Herk7769 is offline
Old 04-25-2012, 05:27 PM   #204
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by billsrvsupplies View Post
Hi Chris
We spoke on the forum earlier this month regards 28 RKBS Wildcat, Ihave a couple of issues that we have encountered
1. The shower tray leaks, the topstep into the bedroom becomes wet when shower is used, I have looked at the waste for leaks and found nothing -does the tray have an upstand lip on the back could this be cracked?
2. Low water pressure in the bathroom sink all other water oulets including the shower real good pressure
vin 4x4fncd25cv026097
Bill
Please send a private message with your contact information and VIN and I'll forward to our service department!
Wildcat Chris is offline
Old 04-25-2012, 05:37 PM   #205
Arrow See the manual...
Originally Posted by Jack67 View Post
have a 2006 Wildcat 5th wheel and I believe the solenoid on the hydraulic pump has gone out. The slide is out and the jacks are up. It there an override or a someway I can manually bring the slide in and the jack down.
Hydraulic slide rooms can be run in manually. See the manual here:
http://www.lci1.com/OwnersManuals/Sl...ideout-Web.pdf
Here's the information (without images) from the Owner's Manual:
The Lippert Hydro-Sync Slideout System can be run with auxiliary power devices like a heavy duty electric drill. In the event of electrical or system failure, this manual method of extending and retracting the slideout room can be used. A standard handheld drill is all that is required. A standard 38" room will take approximately 45 seconds to retract. See the instructions below.
Fig. 5
1. Remove protective label. (See Fig. 5).
2. Using a standard hex bit, insert into auxiliary drive device, i.e.heavy duty electric drill
3. Insert hex bit into coupler found under protective label, Fig. 6
4. Run drill forward or clockwise to extend jacks and in reverse or counterclockwise to retract jacks.
Old 04-26-2012, 03:55 PM   #206
heavyjohn's Avatar
repairing sterling gel coat
chris, just got a 2012 wildcat sterling edition 32rl, would you know if theres a repair kit for the gel coat, to repair dip scratches. thanx john (note iam new to the forum and realy new to posting so if i did this wrong sorry)
heavyjohn is offline
Old 04-26-2012, 04:13 PM   #207
Exclamation Contact your Wildcat dealer!
Please have your Wildcat dealer contact Forest River service for the best advice on this! Scratches are usually a fairly easy fix when done by a professional.
Old 04-26-2012, 04:53 PM   #208
For BILLSRVSUPPLIES,
Have you checked the water lines going to your shower faucet? A lot of times these are not tight and water seeps at the connections and gathers on the plastic sheet under shower. After a while it has no where to go so it ends up seeping out underneath the shower gettting the carpet wet.
burger is offline
Old 05-02-2012, 10:12 PM   #209
muzbomb's Avatar
Hey Chris just wondering where i would get a dust cap i beleive it is. Black cap that goes in the middle of the rim of trailer tire. I just picked up my trailer last Thursday drove it home and noticed that i am missing one cap on one of the wheels?? Also i believe there is suppose to be a cover for the garbage slot in the counter? I am missing one of those as well. I phoned and emailed my dealer but haven't heard back from them??? Guess once you are out the door you are on your own I know it cant cost much so i will buy one if it is easier then warrenty it?? Let me know i live in Canada, Alberta.
Tow Vehical 2012 Dodge Ram 3500 Mega cab Longhorn SRW. White and Chromed out!!!!
Wife's ride 2008 Chev Tahoe, 22x10 Deep dish triple dipped chrome and black rims, Blacked out ride!!!!
2012 Wildcat 323QB
muzbomb is offline
Old 05-02-2012, 10:31 PM   #210
Red face Send me your info via PRIVATE MESSAGE
Please send me your VIN# and contact info (include a shipping address please!) via private message and I'll get this turned over to my service team...
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
