Closed Thread
Old 06-05-2012, 05:31 AM   #231
Originally Posted by jonesj View Post
I'm new at this. 27ft 2002 wildcat fifthwheel. while traveling side panel came loose and began rolling off befor i could stop. Findings- aprox. 2+ ft. of plywood deterioated. one side fiberclass torn aprox 3ft. Other side loose not torn but plywood rotten abt 2 ft back. HELP!!
I understand no warranty; Is there a known fix or is there a layout or print on the sides showing the supports ect. so we can tell where to repair to.
jonesj is offline
Old 06-05-2012, 02:47 PM   #232
JAYCO Representative
Wildcat Chris's Avatar
As recommended before, please see your nearest Wildcat or Forest River dealer for more assistance. They should be able to call in for anything they aren't familiar with!
Wildcat Chris is offline
Old 06-05-2012, 03:15 PM   #233
Chris, We have a 2006 29 RLBS. Is the slideout frame made of wood or metal? The reason I ask is I have some delaminating in the corner of the living room slideout. I have found no leaks and with cabinets across the inside I see no water stains etc... On our trip last year we had a lot of condensation in the cabinets and especially in the area were the delaminating has taken place. Can you have delaminating without a leak? The delaminating is about 12 inches by 12 inches at the most. I did notice that the white covering on top of the slideout is not sticking anymore in that area(corner), but it is still attached and sealed good. Any ideas are welcomed.
Thanks, Tom
mga60tw is offline
Old 06-06-2012, 01:13 PM   #234
Thanks, Tom
Wildcat's slide rooms use the same 2" vacuum-bond lamination process as our sidewalls. While alumimum framing is used, there is also wood present in the build.
I would recommend seeing a reputable Wildcat or Forest River dealer to further assess the situation. Obviously, water and moisture of any kind is our enemy. Hopefully, they'll be able to find a solution for you.
Old 06-15-2012, 03:52 AM   #235
Hey Chris,
Just received our Wildcat Sterling 32RK Wednesday and could not be more thrilled!!!! We do have a couple of questions - we did not receive the CatSense feature on our entry door - is it not available on the 2013 models? Also, does the TV in the main living area pull out and/or swivel? We also ordered the TV mounted in the bedroom- how does the bracket work there? We are looking so forward to camping this weekend in our new camper!!!!
CampinQueen is offline
Old 06-15-2012, 03:42 PM   #236
Originally Posted by CampinQueen View Post
Hey Chris,
I'm happy to hear you got your Wildcat! Please post a photo of it here or on our Facebook page when you have a chance. CatSense was discontinued before the model change -- I do not have an exact date. The TV in the main area of the 32RK does not pull out or swivel; it's attached with an "H" bracket to the wall. I'm unsure what bracket was used in your bedroom to mount the TV as that's not a factory standard or option, but I'll ask the production team next week!
Old 06-15-2012, 10:31 PM   #237
Thanks Chris.....we are on our first camping trip in our new Sterling this weekend!!! Have not found a thing that disappoints us!!!
It's one great camper......love it!!
Old 06-16-2012, 08:35 PM   #238
So Chris my husband now wants to know how to get to the back of the TV to attach our Dish Network receiver with an HDMI cable!! Thanks so much for your help AND patience.
Old 06-16-2012, 09:00 PM   #239
To get the tv out, you just lift straight up. I had to remove our tv last week. The H bracket has upside down tear drop cuts in it that the tv slides down into. I found that if you give it a quick jerk upwards it comes right out as it is tight.
Bob
2012 Wildcat Sterling 29MK
2011 Chevy Silverado 3500HD LTZ 4x4 D/A
4x4man is offline
Old 06-16-2012, 09:01 PM   #240
Where do we get a 2007 brochure? Our dealer is getting a used one and want to see floor plan before taking wife in to see.
gasa765 is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
