06-23-2014, 06:14 PM
#761
Campfire Master
Originally Posted by windylou723
We just bought a new Wildcat 295RSX. We haven't been able to take it camping yet, but want to install a TV in the bedroom before our first trip.
The hookups are all there on the wall, but no sticker or anything to tell us where it's safe to drill for the TV. There should be some kind of "backer board" hiding there in the wall, right? How do we find it? Thanks for any help!!
Just push against the wall with your thumb. As you go along, you should be able to "feel" where the backer board is. Or, you could use a stud sensor. Another trick is to remove the cable connection plate from the wall, then use a mirror to look back there to see it.
John
#762
Campfire Master
Originally Posted by Green Drake
Can't find ours either. We'll be interested in the answer, as well. 2015 295RSX.
Almost positive there isn't one.
John
06-23-2014, 06:18 PM
#763
I'm not close to being Wildcat Chris or a Wildcat factory rep so I there's no warranty expressed or implied by this answer............ but I found this pic doing a Bing search for 295RSX and looked through Images. It has been my experience that the backer board is indeed behind the TV in this pic - just left of the outlets for power and coax. It is also my experience that one can feel said backer board by pounding lightly on the wall about where this TV is mounted. At that point, the wall does not flex and vibrate as the rest of the wall does!!
06-24-2014, 05:24 PM
#764
John
Agree. Found the water pump, finally, no sign of a filter (is that a cost cutting measure?). I always use disposable filters on my city water connection so that will have to suffice. Sometimes I think it's better not to go looking around too much, as seeing how things are put together behind the wall can be disappointing.
F250 Diesel
PullRite 18K
06-24-2014, 06:32 PM
#765
OK< Chris Here's a easy one: I just found a nice 2006 Wildwood T26. Yes it's older but it's so fine!
The data plates in those days didn't show what the allowable cargo weight was/is. I have the VIN number and the gvwr of 7515. If I provide you with the VIN number can you tell me why the allowable cargo weight is?
06-24-2014, 07:27 PM
#766
Tow it empty to the CAT scale and weigh it. Subtract that weight from the GVWR to find your payload.
Once the VIN leaves the lot, payload moves all over the place based on options added by the dealer and the owner.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-25-2014, 03:35 AM
#767
Chris works for Wildcat, NOT Wildwood.
06-26-2014, 08:10 AM
#768
Having said all that, once located, very accessible. just returned from a lengthy road trip which entailed driving thru very heavy thunderstorms. Only a minor leak under one of the slides. In the camp site all systems worked as advertised and the floor plan is very satisfactory for our purposes. Things are looking up !
F250 Diesel
PullRite 18K
06-27-2014, 09:22 AM
#769
Originally Posted by Wildcat Chris
I'll ask production and engineering about this and see if they have any information to share...
Hey Chris. Did you ever hear back from production and engineering about the floor joists.
2014 Wildcat 312BHX
2011 Chevy Silverado 2500HD CCSB 6.0L 4:10
06-29-2014, 01:34 PM
#770
JAYCO Representative
Originally Posted by nole_trainer
Can the 312qbx be ordered with the "party couch" instead of the table/chairs and regular sofa?
YES! The Optional Party Couch Dinette Sleeper is available on all bunk house floor plans (303BHX, 312BHX, 312QBX, 337FB, and 344QB)!
06-29-2014, 01:35 PM
#771
Originally Posted by Cover Dog
Just wondering if I have missed the factory installed filter and now have a 3 filter system or this unit a 2015 282RKX is one that does not come with a filter installed.
Any help from Chris or anyone with knowledge on this subject.
There is no factory installed water filter in Wildcat's build at this time.
06-29-2014, 01:36 PM
#772
Originally Posted by bikendan
they are all low pressure, pretty much throughout the RV industry.
This is correct!
06-29-2014, 01:38 PM
#773
Thanks for that research! There is ⅝" plywood backer throughout a large portion of the bedroom wall (as shown) for TV hook up.
06-29-2014, 01:42 PM
#774
The floor joists in the laminated upper deck are 16" on center. Please call in to the Wildcat plant (574-389-3232) and give your contact information if you need more specific details...
06-29-2014, 03:25 PM
#775
Very NICE! Thanks!
07-03-2014, 05:53 PM
#776
spike
Hi chris, any idea what would cause the wall above the couch slide to go spongy in a 2 foot area?
07-03-2014, 06:03 PM
#777
2007 WildCat 32QBBS
That looks like a water leak. Is there a window above it? Check the roof seam and molding.
07-03-2014, 06:13 PM
#778
spike
No window and i couldnt find a leak. The only thing i could think of was snow on the lip of the slide wall that melted.
07-03-2014, 10:09 PM
#779
Party Couch,
Chris,
Is the party couch something that has to be ordered or can it be installed on a 2013F312BHX model? If so what is the appx. cost? Looks pretty interesting!
Kenn
07-07-2014, 06:38 AM
#780
Chris, finally placed my order last week through RVW!!!!!! Is there a way I can track my build? I used to be able to track an ordered Ford and it was kind of fun to see where it was during the process. And can you make sure my build gets all the TLC
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat |
