07-07-2014, 10:33 AM
#781
Question about the landing gear on my 2013 Wildcat 327CK. Last week while lifting the 5er off my truck, the landing gear stopped working. After investigation, found that the 30 AMP fusible link blew, but not before frying the switch. Luckily it didn't fry the motor. It seams that 30 AMPs is a little much! Suggestions?
JM Wildcat - Jim & Min
2015 Dodge 3500 6.7L Turbo DRW
2013 Wildcat 327CK
2015 Camp Nights: 175
2016 Camp Nights: 121
07-07-2014, 02:08 PM
#782
I think that it went the other way.
Water in the switch fried the switch and then blew the fuse.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-07-2014, 02:24 PM
#783
Sorry - no water in the switch. Completely Dry. And it worked fine putting the trailer on the truck.
2013 Wildcat 327CK
07-07-2014, 02:27 PM
#784
Plus - if you say the 30 Amp fuse is what should be there - then fine. Maybe a warranty issue.
2013 Wildcat 327CK
07-07-2014, 02:28 PM
#785
I guess it just broke then. Happens.
If it was high amperage, the fuse should have let go before the switch took damage. The other way round seems more likely.
07-07-2014, 02:36 PM
#786
The 30 amp single use fuses can blow on the older campers when the gear is full up (or down), the operator continues to hold the switch in, and the motor stalls. This can be fixed by a technical bulletin. (attached)
Note the warning about "over retraction" in the manual.
07-07-2014, 02:48 PM
#787
Thanks for the information! The whole situation seemed odd that the switch and the fuse blew at or about the same time. Would have thought that the fuse would blow first saving the switch and the motor. Started to get irritated when I read "over reaction" then read "retraction". BTW the gear was only 50% up.
As I stated, as long as you and the paperwork says its OK, then we are OK.
2013 Wildcat 327CK
07-07-2014, 02:53 PM
#788
Never heard of one blowing while in transit. Full up was when mine was blowing till I got the button release timing right. I replaced my 30 amp fuse with an auto resetting one and never had an issue again.
07-08-2014, 01:27 AM
#789
JAYCO Representative
Originally Posted by bzzznesman
Chris,
Is the party couch something that has to be ordered or can it be installed on a 2013F312BHX model? If so what is the appx. cost? Looks pretty interesting!
Kenn
The Party Couch Dinette/Sleeper Sofa (available in all bunk house models in place of hide-a-bed and dinette, MADE IN U.S.A.!) is a factory installed option. However, it's feasible that it could be installed in a unit later. Please call your Wildcat dealer to inquire further and/or call Wildcat's parts department directly for pricing and availability: 574-206-7615
07-08-2014, 01:28 AM
#790
Originally Posted by nole_trainer
Chris, finally placed my order last week through RVW!!!!!! Is there a way I can track my build? I used to be able to track an ordered Ford and it was kind of fun to see where it was during the process. And can you make sure my build gets all the TLC
I'll have to check into this in more detail… please send me a private message with your complete contact information and I'll see what I can do!
07-09-2014, 05:45 PM
#791
Is the 2015 Wildcat 327 ck available with the fireplace "brick" look surround. I have seen it on the 2014 but all the 2015 pics I have seen it is not there. thanks
07-09-2014, 06:00 PM
#792
Phat Phrog Stunt Crew
Originally Posted by Wildcat Chris
All 2015 Wildcats feature a cherry hardwood fire place surround. The faux rock/brick is no longer offered.
scchasgal, This was Wildcat Chris's reply on post 741
2014 Wildcat 327ck
07-09-2014, 06:19 PM
#793
thanks I was just heading through the posts
07-10-2014, 07:09 AM
#794
Although we've changed to a hardwood cherry surround now, we may have a limited supply left of the faux "rock" fireplace surround through our parts department. If this is something you're looking for, please discuss this with your local Wildcat dealer or let me know if you need more information on ordering it via Wildcat's parts department.
07-10-2014, 07:46 AM
#795
2011 Brookstone 37
My Tech is having problems with the wiring going to the control remote brain to the front jacks to jack motor. The brain was fried so we got a new one from Lippert. Lippert doesn't have any wiring diagram. Forest River doesn't have wiring diagram, Coachman Doesn't have wiring diagram DAH how do they make these?
I need to know where the wires go from switch (orange wire, red wire, black wire, white wire) Motor is reversable I know black and white.
Can anyone help or have a number I can call. My tech and I have all the places above with no luck.
If someone can look in there 5r and tell me what wires are connected it would help.
We think what fried the brain was the lift motor
2015 Bighorn 37' Front Living Room
2012 Dodge Cummins 3500 4x4
Live at 9000' in the rockies just out of Colorado springs
07-14-2014, 04:09 PM
#796
2004 27rl tire size
I keep my 27rl in storage about 150 miles from my home. I know its time to purchase new tires for my camper. Can you tell me what the tire size I need?
07-25-2014, 09:04 AM
#797
reservoir level?
Chis,
I just purchased a Wild Cat 30rlbs 5th wheel.
Could you tell me what level the hydraulic fluid should be maintained at in the slide out reservoir ...and is it 'any' ATF fluid ?
Thank you
Dennis
Nanaimo B.C.
07-25-2014, 10:36 AM
#798
mine has a full mark
07-26-2014, 07:46 AM
#799
'onetexasoldman'... thanks for your reply.
I do not see any "fill line" , however, about 1/3 up from bottom there is a bold black line between some wording, but nothing pertaining to 'full' or 'fill to' .
The reservoir is about 1/2 full now.
I think I will top it off with ATF to about 1 to 1 1/2 inches below the top "With the Slides In".
Certainly do not want it gushing out the breather cap when the rams return all that oil back to the reservoir....now would I ?
Dennis
Nanaimo B.C.
07-26-2014, 07:56 AM
#800
I couldn't believe how much oil leaves when all 4 slides go out
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat |
