Closed Thread
Old 01-31-2014, 04:27 PM   #601
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by rockmike View Post
Has production started on the 295RSX? I ordered one when the floor plan first came out, but haven't heard anything about delivery. Any pics of this unit?
We have started production! Units are beginning to land on the ground at dealers across the US and Canada now!
There will be photos of the 295RSX on the Forest River web site soon -- I'll post back when they are up!
Wildcat Chris is offline
Old 01-31-2014, 04:55 PM   #602
Thanks for the info.
rockmike is offline
Old 02-09-2014, 10:37 PM   #603
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
MOr/ryde pin box model number
Chris, we have about 6 weeks before delivery of our Wildcat 282 RKX and need to know about the pin box assembly.
We have a Pullrite Superglide #4100 and need a capture plate to attach to the underside of the pin box to be able to use the the Pullrite auto slider. Can you tell me what model Mor/ryde pin box we will have on our 282RKX so we can order the capture plate.
Thanks,
Bill Schnauffer aka......Cover Dog
Chardon, Ohio
Cover Dog is offline
Old 02-10-2014, 08:53 AM   #604
jevanb's Avatar
you need http://www.morryde.com/phpThumb/phpT...-001.jpg&w=280
http://www.morryde.com/aftermarket/r...daptor-43.html
if you need a tow from somebody else you need to remove the capture plate or get the 3336 Conversion Adapter from pullrite, or buy mine because it do not need it
http://www.pullrite.com/sites/pullri...?itok=dHby4T08
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline
Old 02-10-2014, 09:43 AM   #605
Herk7769's Avatar
MOR/ryde Products
I thought about buying the conversion plate, but my capture plate is so easy to remove if needed that I decided not to get (and CARRY!) it.
Your dealer should be able to tell you what pin box they are installing as soon as they get a VIN number from FR. They had mine in time for me to order the correct capture plate from RV Warehouse and get it delivered before the camper arrived at the dealership.
You should not buy the universal capture plate, because if you get the pin box number you may find that there is a correct one (that is easy to remove) for the box they install.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 02-12-2014, 08:05 AM   #606
Thanks,
Chardon, Ohio
I'll get this information for and will advise!
Old 02-12-2014, 01:04 PM   #607
Double Towing with Ultra Light 8244ws
Searching double towing has not turned up an answer for this question. Our state allows double tow up to 65' and our past usage indicates that a small 5th wheel is best suited for us such as the 8244ws. Adding a hitch that would support a pin weight of 300-500 would be what we desire. Is that frame on the 8244ws stout enough for such a receiver? If not which 5ver in the Forest River lineup under 28 ft does have a strong enough frame. Is the frame tubular or I beam? What is the thickness of the metal in the frame?
Also on another forum it was stated that the bonded floor on the 8244s is topped with a thin plywood, such as luan (1/8) inch. An individual who has one said that where the laundry chute it measures as 3/4. The brochure shows the bonding and would seem that the outer layers are very thin.
Stetwood is offline
Old 02-12-2014, 03:59 PM   #608
Thumbs up MORryde Part #SPB72-1621LD 12K Pin Box
MOR/ryde Part #SPB72-1621LD 12K Pin Box is what's installed on the 282RKX (and all other eXtraLite models).
Old 02-12-2014, 04:01 PM   #609
I wish I could help you, but you might have better luck in the Rockwood forum:
Rockwood - Forest River Forums
Old 02-12-2014, 05:30 PM   #610
Herk7769's Avatar
http://www.pullrite.com/sites/pullri...it%20Chart.pdf
Looks like they have a capture plate for your pinbox.
Herk7769 is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
