Closed Thread
Old 02-22-2014, 04:42 PM   #621
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by cornfed78 View Post
Hi Chris,
I just got back from the MD RV Show, and had a good chat with one of the factory reps. I have a couple of questions I forgot to ask that I hope you can answer, and a couple more that I'm hoping you can confirm. Thanks in advance for any advice you can offer.
Here are the questions:
  1. Is the 2nd bedroom AC on this model ducted?
  2. If I order now, will the 282RKX have the new NXG Frame? The rep said that it should.
  3. Do the models coming from the factory have the TV on a swing/swivel arm? The one at the show didn't.
  4. Does the utility area have the water heater bypass/winterization valves in it? The one in the show didn't.
Thanks again!
Matt
1. The 2nd AC location is dual-ducted. All Wildcats are setup this way!
2. Current 282RKX models have the NXG frame now (made by BAL)! New 282RKX orders will also now include our exclusive drop frame build (like the 295RSX)!
3. All Wildcat models being built today have a lockable swing arm on the main TV.
4. The docking station changes took place in late fall. ALL newly built Wildcat units have the new setup!
Wildcat Chris is offline
Old 02-22-2014, 04:54 PM   #622
Awesome- thanks so much for the quick reply!
cornfed78 is offline
Old 02-22-2014, 09:43 PM   #623
Wildcat Chris
Does that mean that the 282rkx has a 60 gallon tank or a 50 gallon tank with a 10 gallon water heater?
jchild is offline
Old 02-22-2014, 09:55 PM   #624
Originally Posted by jchild View Post
Wildcat Chris
All fresh water tanks on current Wildcat production is 50 gallon capacity. A 10 gallon water heater is standard too. Total fresh water capacity is 60 gallons (this is industry standard for fresh water capacity measurements: FRESH + WATER HEATER).
Old 02-22-2014, 09:56 PM   #625
Chris
Thank-you for the reply. Is clears up a lot of confusion.
jchild is offline
Old 03-09-2014, 06:39 PM   #626
wildcat 293REX TV mount
I have a 2013 293REX. The TV mount in the living area has broken for a second time. The first time I did not look at any of it. I just took it back to the dealership to fix it. This was our first outing in it. The mount has broken for a second time. This time I took a closer look at what happened. On the inside of the entertainment center I found part of one of the gears that raises and lowers the TV. I noticed the gear is plastic. Can this gear be replaced with a metal one so I won't have to go through this again?
2013 Wildcat 293REX
2010 Dodge 2500 TRX4
bfuqua99 is offline
Old 03-11-2014, 01:23 AM   #627
Please send me a private message with your complete contact information and Wildcat VIN#. I'll ask my service team to look into this for you!
Old 03-11-2014, 08:29 PM   #628
Phat Phrog Stunt Crew
elind's Avatar
Chris,
Closing a deal on a 2014 Wildcat 327ck this week. We have been looking at it since Goshen. Now I need to find a truck to pull it.
Does the washer/dryer combo set up have a dryer vent? I didn't see any pics of a vent.
2014 Wildcat 327ck
elind is offline
Old 03-11-2014, 08:42 PM   #629
Originally Posted by elind View Post
Chris,
Congrats! Welcome to the Wildcat family!
I believe there is vent access through the floor -- I know they put a sticker on the underside of the bedroom deck showing the intended location. Please let me know if you need more information and I'll get with my crew here...
Old 03-12-2014, 11:30 AM   #630
jeepman71's Avatar
Wildcat Chris,
My wife and I are in the process of moving from a 2013 Rockwood to a 2014 317RLS. My quest is concerning the slides. This model does not offer the ability to lock out one slide or another like some of the FR products do. Can you tell me if it would be possible and affordable to add an ICR valve similar to the Silver Back?
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
