Closed Thread
Old 06-23-2014, 06:14 PM   #761
Campfire Master
Originally Posted by windylou723 View Post
We just bought a new Wildcat 295RSX. We haven't been able to take it camping yet, but want to install a TV in the bedroom before our first trip.
The hookups are all there on the wall, but no sticker or anything to tell us where it's safe to drill for the TV. There should be some kind of "backer board" hiding there in the wall, right? How do we find it? Thanks for any help!!
Just push against the wall with your thumb. As you go along, you should be able to "feel" where the backer board is. Or, you could use a stud sensor. Another trick is to remove the cable connection plate from the wall, then use a mirror to look back there to see it.
John
AVid is offline
Old 06-23-2014, 06:14 PM   #762
Campfire Master
Originally Posted by Green Drake View Post
Can't find ours either. We'll be interested in the answer, as well. 2015 295RSX.
Almost positive there isn't one.
John
AVid is offline
Old 06-23-2014, 06:18 PM   #763
Mr. Dan's Avatar
I'm not close to being Wildcat Chris or a Wildcat factory rep so I there's no warranty expressed or implied by this answer............ but I found this pic doing a Bing search for 295RSX and looked through Images. It has been my experience that the backer board is indeed behind the TV in this pic - just left of the outlets for power and coax. It is also my experience that one can feel said backer board by pounding lightly on the wall about where this TV is mounted. At that point, the wall does not flex and vibrate as the rest of the wall does!!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Mr. Dan is offline
Old 06-24-2014, 05:24 PM   #764
John
Agree. Found the water pump, finally, no sign of a filter (is that a cost cutting measure?). I always use disposable filters on my city water connection so that will have to suffice. Sometimes I think it's better not to go looking around too much, as seeing how things are put together behind the wall can be disappointing.
2015 FR Wildcat 295RSX
F250 Diesel
PullRite 18K
Green Drake is offline
Old 06-24-2014, 06:32 PM   #765
OK< Chris Here's a easy one: I just found a nice 2006 Wildwood T26. Yes it's older but it's so fine!
The data plates in those days didn't show what the allowable cargo weight was/is. I have the VIN number and the gvwr of 7515. If I provide you with the VIN number can you tell me why the allowable cargo weight is?
hankpac is offline
Old 06-24-2014, 07:27 PM   #766
Herk7769's Avatar
Tow it empty to the CAT scale and weigh it. Subtract that weight from the GVWR to find your payload.
Once the VIN leaves the lot, payload moves all over the place based on options added by the dealer and the owner.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 06-25-2014, 03:35 AM   #767
bikendan's Avatar
Chris works for Wildcat, NOT Wildwood.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
bikendan is offline
Old 06-26-2014, 08:10 AM   #768
Having said all that, once located, very accessible. just returned from a lengthy road trip which entailed driving thru very heavy thunderstorms. Only a minor leak under one of the slides. In the camp site all systems worked as advertised and the floor plan is very satisfactory for our purposes. Things are looking up !
F250 Diesel
PullRite 18K
Old 06-27-2014, 09:22 AM   #769
Originally Posted by Wildcat Chris View Post
I'll ask production and engineering about this and see if they have any information to share...
Hey Chris. Did you ever hear back from production and engineering about the floor joists.
2014 Wildcat 312BHX
2011 Chevy Silverado 2500HD CCSB 6.0L 4:10
Bogey is offline
Old 06-29-2014, 01:34 PM   #770
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by nole_trainer View Post
Can the 312qbx be ordered with the "party couch" instead of the table/chairs and regular sofa?
YES! The Optional Party Couch Dinette Sleeper is available on all bunk house floor plans (303BHX, 312BHX, 312QBX, 337FB, and 344QB)!
Wildcat Chris is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
