Closed Thread
Old 07-07-2014, 10:33 AM   #781
Question about the landing gear on my 2013 Wildcat 327CK. Last week while lifting the 5er off my truck, the landing gear stopped working. After investigation, found that the 30 AMP fusible link blew, but not before frying the switch. Luckily it didn't fry the motor. It seams that 30 AMPs is a little much! Suggestions?
JM Wildcat - Jim & Min
2015 Dodge 3500 6.7L Turbo DRW
2013 Wildcat 327CK
2015 Camp Nights: 175
2016 Camp Nights: 121
JM Wildcat is offline
Old 07-07-2014, 02:08 PM   #782
Herk7769's Avatar
I think that it went the other way.
Water in the switch fried the switch and then blew the fuse.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 07-07-2014, 02:24 PM   #783
Sorry - no water in the switch. Completely Dry. And it worked fine putting the trailer on the truck.
2013 Wildcat 327CK
Old 07-07-2014, 02:27 PM   #784
Plus - if you say the 30 Amp fuse is what should be there - then fine. Maybe a warranty issue.
2013 Wildcat 327CK
Old 07-07-2014, 02:28 PM   #785
Herk7769's Avatar
I guess it just broke then. Happens.
If it was high amperage, the fuse should have let go before the switch took damage. The other way round seems more likely.
Herk7769 is offline
Old 07-07-2014, 02:36 PM   #786
Herk7769's Avatar
The 30 amp single use fuses can blow on the older campers when the gear is full up (or down), the operator continues to hold the switch in, and the motor stalls. This can be fixed by a technical bulletin. (attached)
Note the warning about "over retraction" in the manual.
Herk7769 is offline
Old 07-07-2014, 02:48 PM   #787
Thanks for the information! The whole situation seemed odd that the switch and the fuse blew at or about the same time. Would have thought that the fuse would blow first saving the switch and the motor. Started to get irritated when I read "over reaction" then read "retraction". BTW the gear was only 50% up.
As I stated, as long as you and the paperwork says its OK, then we are OK.
2013 Wildcat 327CK
Old 07-07-2014, 02:53 PM   #788
Herk7769's Avatar
Never heard of one blowing while in transit. Full up was when mine was blowing till I got the button release timing right. I replaced my 30 amp fuse with an auto resetting one and never had an issue again.
Herk7769 is offline
Old 07-08-2014, 01:27 AM   #789
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by bzzznesman View Post
Chris,
Is the party couch something that has to be ordered or can it be installed on a 2013F312BHX model? If so what is the appx. cost? Looks pretty interesting!
Kenn
The Party Couch Dinette/Sleeper Sofa (available in all bunk house models in place of hide-a-bed and dinette, MADE IN U.S.A.!) is a factory installed option. However, it's feasible that it could be installed in a unit later. Please call your Wildcat dealer to inquire further and/or call Wildcat's parts department directly for pricing and availability: 574-206-7615
Wildcat Chris is offline
Old 07-08-2014, 01:28 AM   #790
Originally Posted by nole_trainer View Post
Chris, finally placed my order last week through RVW!!!!!! Is there a way I can track my build? I used to be able to track an ordered Ford and it was kind of fun to see where it was during the process. And can you make sure my build gets all the TLC
I'll have to check into this in more detail… please send me a private message with your complete contact information and I'll see what I can do!
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
