Closed Thread
Old 01-16-2012, 07:53 AM   #71
JAYCO Representative
Wildcat Chris's Avatar
Wink Glad to be of service!
Originally Posted by cherrykiss3 View Post
Thanks Chris that is just what I needed.
Cherry
No problem Cherry! It's why I'm here!
Wildcat Chris is offline
Old 01-16-2012, 09:02 PM   #72
Question about hydraulic operation
Did not receive a reply in the main forum so I thought I would direct my question to the company reps - hope you dont mind
I am trying to help out my father who just purchased a 2005 Wildcat and I believe the model is 28RK.
It has hydraulic jacks and slide. There is a button in the trailer that is for the slide and there is a button in the front on the outside to lower the jacks.
On his first trip he had some fellow campers help him and the issue is that those two switches do the same thing.
When the trailer is parked you hitch up, raise the jacks and then the slide starts to come in.
When ready to move you do the same thing except the slide comes in first and then the jacks go up. The only inconvenience is that sometimes you may want to raise or lower the jacks and not mess with the slide.
Does anyone know if this is the normal operation on these or is something not hooked up right. (I can post a picture later if that will help)
Thanks in advance!
Michael
faithalone is offline
Old 01-16-2012, 09:33 PM   #73
onetonford's Avatar
If I remember right someone else had same problem and the solution is that at the pump there is a bypass valve that should be closed down tight and then they will work as they should it is possible sombody opened this valve causing your problem.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline
Old 01-17-2012, 04:54 AM   #74
Do you know what this valve looks like? Thanks so much!
Old 01-17-2012, 04:04 PM   #75
muzbomb's Avatar
PM sent
Tow Vehical 2012 Dodge Ram 3500 Mega cab Longhorn SRW. White and Chromed out!!!!
Wife's ride 2008 Chev Tahoe, 22x10 Deep dish triple dipped chrome and black rims, Blacked out ride!!!!
2012 Wildcat 323QB
muzbomb is offline
Old 01-18-2012, 07:43 AM   #76
Originally Posted by muzbomb View Post
PM sent
PM sent back... I'm looking into the details and I'll get back to you.
Old 01-18-2012, 07:44 AM   #77
I'll see if I can get some guidance on this from our production team...
Old 01-18-2012, 07:47 AM   #78
Thank you Chris!
Old 01-18-2012, 08:26 AM   #79
TomCat's Avatar
If you would contact the Wildcat service department and ask for Rod @ 574 206 7600 he can get you answers ASAP that will get you going!
Safe travels,
Tomcat
TomCat is offline
Old 01-18-2012, 10:14 AM   #80
muzbomb's Avatar
Thanks Chris!!!!
2012 Wildcat 323QB
muzbomb is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
