Closed Thread
Old 07-09-2014, 05:45 PM   #791
Is the 2015 Wildcat 327 ck available with the fireplace "brick" look surround. I have seen it on the 2014 but all the 2015 pics I have seen it is not there. thanks
scchasgal is offline
Old 07-09-2014, 06:00 PM   #792
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by Wildcat Chris View Post
All 2015 Wildcats feature a cherry hardwood fire place surround. The faux rock/brick is no longer offered.
scchasgal, This was Wildcat Chris's reply on post 741
2014 Wildcat 327ck
elind is offline
Old 07-09-2014, 06:19 PM   #793
thanks I was just heading through the posts
Old 07-10-2014, 07:09 AM   #794
JAYCO Representative
Wildcat Chris's Avatar
Although we've changed to a hardwood cherry surround now, we may have a limited supply left of the faux "rock" fireplace surround through our parts department. If this is something you're looking for, please discuss this with your local Wildcat dealer or let me know if you need more information on ordering it via Wildcat's parts department.
Wildcat Chris is offline
Old 07-10-2014, 07:46 AM   #795
onetexasoldman's Avatar
2011 Brookstone 37
My Tech is having problems with the wiring going to the control remote brain to the front jacks to jack motor. The brain was fried so we got a new one from Lippert. Lippert doesn't have any wiring diagram. Forest River doesn't have wiring diagram, Coachman Doesn't have wiring diagram DAH how do they make these?
I need to know where the wires go from switch (orange wire, red wire, black wire, white wire) Motor is reversable I know black and white.
Can anyone help or have a number I can call. My tech and I have all the places above with no luck.
If someone can look in there 5r and tell me what wires are connected it would help.
We think what fried the brain was the lift motor
2015 Bighorn 37' Front Living Room
2012 Dodge Cummins 3500 4x4
Live at 9000' in the rockies just out of Colorado springs
onetexasoldman is offline
Old 07-14-2014, 04:09 PM   #796
2004 27rl tire size
I keep my 27rl in storage about 150 miles from my home. I know its time to purchase new tires for my camper. Can you tell me what the tire size I need?
kmangan1 is offline
Old 07-25-2014, 09:04 AM   #797
Islander's Avatar
reservoir level?
Chis,
I just purchased a Wild Cat 30rlbs 5th wheel.
Could you tell me what level the hydraulic fluid should be maintained at in the slide out reservoir ...and is it 'any' ATF fluid ?
Thank you
Dennis
Nanaimo B.C.
Islander is offline
Old 07-25-2014, 10:36 AM   #798
mine has a full mark
Old 07-26-2014, 07:46 AM   #799
Islander's Avatar
'onetexasoldman'... thanks for your reply.
I do not see any "fill line" , however, about 1/3 up from bottom there is a bold black line between some wording, but nothing pertaining to 'full' or 'fill to' .
The reservoir is about 1/2 full now.
I think I will top it off with ATF to about 1 to 1 1/2 inches below the top "With the Slides In".
Certainly do not want it gushing out the breather cap when the rams return all that oil back to the reservoir....now would I ?
Dennis
Nanaimo B.C.
Islander is offline
Old 07-26-2014, 07:56 AM   #800
I couldn't believe how much oil leaves when all 4 slides go out
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
