Closed Thread
Old 08-01-2014, 07:52 PM   #821
PPST OGCDG
Frank-VA's Avatar
hydraulic pump problems
http://lci1.com/images/support/manua...ble-manual.pdf
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline
Old 08-02-2014, 07:41 AM   #822
onetexasoldman's Avatar
My pump is also in the front compartment and it was only clicking. What I had to do was run a jump wire from the battery to the middle pole on the solenoid and hold it while the wife pushed the button inside to work the slides. After taking it to the tech I don't know what he did to get it working again. I did have power to the switch but not enough to work the slides.
2015 Bighorn 37' Front Living Room
2012 Dodge Cummins 3500 4x4
Live at 9000' in the rockies just out of Colorado springs
onetexasoldman is offline
Old 08-02-2014, 01:14 PM   #823
Thanks. Our pump is not in the front compartment. We think it is right near the slide base on where we hear the clicking but there is no way to get to it without taking the whole bottom off the trailer including all the foam sealing joints. So this trip we will go with no slide out. Like a blast from the past. We are on our way.
Taylor is offline
Old 08-02-2014, 07:58 PM   #824
21 FBRS Exterior Height
I love the floor plan of the 21 FBRS.
The specs I saw for the 21 FBRS shows the exterior height as 10'1".
Is this with the A/C?
Our garage door is 10 feet, and the interior of the garage is 12 feet.
What is the actual exterior height, and if we replaced the A/C with a low profile A/C, do you think it would fit thru our 10 foot door?
Any other suggestions with this 10 foot door limitation? Thanks!
gigi is offline
Old 08-03-2014, 08:47 AM   #825
Islander's Avatar
TV Wall Mount ??
My Wildcat 30 RLBS location for the TV is too small ...width wise.
I hope to mount a TV on the wall (where the mirror is/was) just above the normal TV location.
My background as a finish carpenter tells me there are two 2x3 vertical studs that may do the job between the TV wall location and the cabinet wall , located in the toilet room.
With the convenient TV wall mounting brackets available I hope this will prove successful.
Has anyone else done this ?
Any input would be appreciated?
Thank you
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline
Old 08-07-2014, 09:48 AM   #826
jwm
Chris,
We just bought a 344qu-ok and can not locate the switch for the overhead lights in the main body. I realize that this maybe due to a burned out fuse or bulb, but still am unable to determine which switch controls them. Also, am missing the remote for the air bed. What is the best source for replacement. Thanks!
jwm is offline
Old 08-07-2014, 11:28 AM   #827
jevanb's Avatar
Originally Posted by jwm View Post
Chris,
our 344 has the switch just inside the door
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline
Old 08-19-2014, 06:50 AM   #828
JAYCO Representative
Wildcat Chris's Avatar
Chris,
I'm hoping the post above helped!
As for replacement parts, pleas try Wildcat's parts department:
Kyle Hilliard
Wildcat Parts Representative (Elkhart)
574-206-7615
khilliard (at) forestriverinc.com
Wildcat Chris is offline
Old 08-19-2014, 06:52 AM   #829
Unfortunately, this is not a Wildcat and I can't advise on this! Please try the Flagstaff forum: Flagstaff - Forest River Forums
Old 08-19-2014, 06:57 AM   #830
Originally Posted by Taylor View Post
We have a 2011 Forest River Wildcat Travel trailer model WCT27RLS. It has never given us any trouble. We last used it 2 weeks ago. Today we are packing up to go on a trip tomorrow am and the slide will not go out. It goes click click click when we press the out button. It is plugged in and the fuse looks good. Any suggestions? Is there a manual way to get the slide out (it talks about one in the manual but we can't find where to do it) if we can't get this problem fixed today? Help! Thanks.
The 27RLS travel trailer wouldn't have a hydraulic slide -- it uses an electric slide mechanism from Lippert Components. See more information here:
2 x 3 Electric Slide System - Through Frame - Slide-Outs - Customer Support
Here's a helpful video as well:
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
