Closed Thread
Old 08-21-2014, 10:12 PM   #841
Herk7769's Avatar
Originally Posted by gljurczyk View Post
Herk, I just love your library. You have something on everything you should be a rep....
Just trying to keep the shiny side up!
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 08-22-2014, 09:23 AM   #842
BamaBob's Avatar
Glenn,
When i was talking to Herk at Goshen, I made mention I would like to get a copy of his library.
He said sure, just send me a portable 3 TERABYTE drive and I can copy it for you
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline
Old 08-22-2014, 09:25 AM   #843
BamaBob's Avatar
Speaking of which Herk, after a "small incident" on the way back from Goshen...what Brand/Model of Dash Camera do you use?
BamaBob is offline
Old 08-22-2014, 04:36 PM   #844
Herk7769's Avatar
Bought two "cheapies" at last year's rally and one failed. I replaced it at this year's rally with the f20 double camera car camcorder. Seems to work great with one wide angle "steerable" and one tight zoom "steerable" cameras.
CAR CAMCORDER F20 | eBay
NOT MY CAMERA! TURN OFF AUDIO on the first video
Herk7769 is offline
Old 08-22-2014, 04:37 PM   #845
Herk7769's Avatar
Glenn,
Oh, I miss understood. I thought you wanted my "entertainment" library and not the Herkbrary. The Herkbrary sits right at 160 gigabytes right now.
Herk7769 is offline
Old 08-26-2014, 02:10 PM   #846
Wildcat 337fb living room slide does not close properly. When I close the living room slide the whole thing closes right until half way. Then the top seemingly gets stuck (yes, I checked the roof and interior). It will look crooked and the floor inside lifts up on an angle. I then slide it back out about a foot or so and back in. So far that works, but is that a problem I should be concerned about?
GaryJCoz is offline
Old 08-26-2014, 04:24 PM   #847
Witch Doctor's Avatar
Where you level when this happened? If yes then I would get it checked out.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is offline
Old 08-26-2014, 04:27 PM   #848
Yes. I was level both times it happened. Both were leaving campgrounds, and I use a 4 foot level when I setup camp.
GaryJCoz is offline
Old 08-26-2014, 04:34 PM   #849
It looks like your still in warranty? Take it in you have to had to come out of adjustment. What kinda of slide is it, electric or hydraulic? There are some good u-tube under lippert slides take a look at them. That is not Normal what you have described. You might be able lay under it and have someone bring it in and see if you are seeing anything binding. Good Luck
Old 09-01-2014, 07:21 PM   #850
plan
J aimerai savoir si c est possible d avoir le plan électrique et l emplacement des réservoirs d eau pour wildcat 282 rkx 2014
Je reside au Quebec
P.s. quelque petite chose a améliorée ,les 2 table de chevet sont trop large avec les drap et la douillete est trop serrée . La porte coulissante pourrait être plus haute de 3 pouce pour cacher plus de lumière du dome de la douche. La prise d air du plancher près de la porte arrive en dessous du fauteuil.
Merci de prendre du temps pour me lire
mach670 is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
