Closed Thread
Old 03-17-2015, 12:49 PM   #941
jonrjen's Avatar
Brian Knight is a top notch asset to the Forest River Company. It would be nice if more of the higher up in the company could follow in his footsteps.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline
Old 03-24-2015, 02:34 PM   #942
bpdlk33's Avatar
Slab Hunter I was one year out of factory warranty with my FR 5th wheel and found my never lube bearings were starting to come apart. A common problem and a safety hazard. My dealer dealt with FR factory and he got and installed new 6000lb axles and easy lube bearings at no cost to me. He was paid by FR to do the work.
bpdlk33 is offline
Old 04-23-2015, 04:25 PM   #943
Hi Chris. My name is Mike and I have a 2010 Wildcat 31TS fiver. I have a problem with the 12 volt system. I put new batteries in and, just on the batteries, the hydraulics work fine but the other 12 volt things (light, fan, etc) don't. When I plug into the house everything works. I've checked all the fuses and they're OK. However, the led lights on the converter that light up when you pull a fuse don't come on (most don't anyway) when I pull that fuse. I also checked the reverse polarity fuses & they're OK. Any thoughts?? Is the converter screwed??
Miller.va is offline
Old 04-23-2015, 04:28 PM   #944
TURBS's Avatar
Resetable circuit breaker near the battery.
Check that.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
TURBS is offline
Old 04-23-2015, 04:31 PM   #945
Herk7769's Avatar
There is another one under the pin box under the red cover.
The reset button is on one of the short sides:
It could also be corrosion on the terminals.
A bit of sandpaper may make it all better.
ID:	75038   Click image for larger version
ID:	75039   Click image for larger version
Name:	Camper Photos 003.jpg
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 04-23-2015, 04:47 PM   #946
67cudafb's Avatar
Really! I sent him email about 3 weeks ago and got zero response!
67cudafb is offline
Old 04-23-2015, 05:29 PM   #947
Thanks for the super quick replies. I did find the red rubber covered one that comes directly from the battery. It has a little black button & I pushed it & nothing happens. I can't find one under the slides. I have a Reese 5th Airborne hitch and the truck is not connected. The 12 volt stuff still won't work just off the batteries, but the hydraulic slides work just fine as the power comes directly from the batteries. Any other ideas?
Old 04-23-2015, 05:48 PM   #948
Bpdlk What model camper do you have?
gtdmce is offline
Old 04-23-2015, 05:51 PM   #949
Wildcat 31TS. The slides are hydraulic, work directly off the batteries, and work fine just on battery.
Old 04-23-2015, 06:13 PM   #950
onetonford's Avatar
Mine has nothing at the hitch. But down by the pump on mine to the left is a rubber flat that is covering several of those circuit breakers. mine auto reset but yours might not. also need to see if it has a battery disconnect switch some do. check the attached files.
ID:	75049   Click image for larger version
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
