Closed Thread
Old 04-23-2015, 06:27 PM   #951
Herk7769's Avatar
Originally Posted by Miller.va View Post
Thanks for the super quick replies. I did find the red rubber covered one that comes directly from the battery. It has a little black button & I pushed it & nothing happens. I can't find one under the slides. I have a Reese 5th Airborne hitch and the truck is not connected. The 12 volt stuff still won't work just off the batteries, but the hydraulic slides work just fine as the power comes directly from the batteries. Any other ideas?
There is a resettable current limiter near the battery to protect the battery from a direct short. There is also a similar current limiter (in all trailers) located very close to the metal box that the umbilical cord goes into. This protects the camper from a direct short as a result of a severed/shorted umbilical.
It is there; 5th wheel or travel trailer, you may just not have found it yet.
ID:	75047   Click image for larger version
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 04-23-2015, 06:36 PM   #952
Thanks for all the responses & onetonford is the MAN!! I never know that those little boxes has resets on them. There are 3 & the middle one has no reset. The bottom one was popped & resetting it does the trick. Never had any problems before & learning is good. Thanks again!!
MJMinDE
2012 Ram 2500 CTD, BullyDog, AFE, 50 gal aux tank
2010 Wildcat 31TS 5th wheel, Reese 5th Airborn
2018 WILDWOOD 201BHXL
Miller.va is offline
Old 04-23-2015, 06:45 PM   #953
Thanks Herk7769. I did find the one coming directly off the battery but it wasn't popped. Onetonford came up with the answer. Thanks again & I'll look for the other red rubber covered limiter. Funny, put 15K miles to AK & back & never had a problem & problem happens sitting in driveway.
MJMinDE
Old 04-23-2015, 07:45 PM   #954
Herk7769's Avatar
You may find that corrosion (high resistance joint) at the wire terminals could have been the problem. Opening a slide after a long winter's sleep may draw more amps than normal; coupled with current loss at the joint may have put you over the top.
My limiter under the 5th wheel pin box failed due to corroded terminals. You can actually see the burned red wire going into the red cover in the photo.
Slides and front jacks worked on battery but converter power was not getting to the battery to charge it. With this limiter open the truck would not charge the battery either.
My wiring diagram:
Name:	My wiring diagram.jpg
ID:	75060   Click image for larger version
Name:	NO POWER to 12 VDC.jpg
Herk7769 is offline
Old 04-28-2015, 05:02 PM   #955
Rear jacks not working
I've got another problem with my Wildcat 31TS. The rear jacks won't work. I checked the circuit breakers under the black rubber flap & they're OK. Anybody else have this problem?
Old 05-21-2015, 08:54 AM   #956
I recently bought a 295RSX, and I am looking to change out the standard king pin box. Question is that I have looked at MOR ryde, and Ariryde systems, but confused on what the one on there currently is. The sticker says MOR ryde SPB72-1621LD, but whenever you look up your system on the various websites, they never list morryde as an option for your current system. Any help or advice would be appreciated.
2015 Ford F-250 SuperCrew 6.7L w/Firestone Ride Rite Air Bags
2015 Forest River Wildcat Extra Lite 295RSX
Days Camped 2015 - 37
jkrise is offline
Old 05-21-2015, 10:52 AM   #957
Islander's Avatar
Sorry... it looks like this thread may have been hijacked...sorry if it was.
jkrise......
Just to help confuse you a little...
I have a Wildcat 30rlbs and hated the stock pin box .
In the truck I have double pivot 5th wheel hitch.
I experienced severe chucking and when we hit dips or bumps in the road the jaw shattering thuds were carried right through the whole truck & rig.
I too looked at MOR ryde, and Ariryde systems.
The Mor-ryde would take care of the 'chucking'... and the Air-ryde would certainly help with the 'cushioning' of the dips and bumps.
However, I chose the "Ultra-Fab Trail Air Tri-Glide 5th Wheel King Pin Box."
I recently came back from the maiden trip with the new Trail Air Pin Box and I was astounded at the difference and improvement this made to our 30 day trip.
No chucking, smooth starts and stops, no jaw shattering thuds.
The 5th wheel glided along behind ... the dips and bumps were cushioned nicely by the air bag...I could see the action in the rear view mirror.
Note: as a 'test' I set up some items inside the 5th wheel, bottles in the cupboard, a plastic buckle on the table, a cd disc on a shelf ....all these items and more were exactly in the same spot upon arrival.... from experience prior the Trail Air Pin Box I know that "everything" had to be lashed down and tucked away.
The softer ride can only be easier on the 5th wheel frame as well for the truck and most certainly... more comfortable for the driver and passengers.
in closing...I am a "happy camper" with my 'Trail Air Tri-Glide Air Ride '.
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline
Old 05-22-2015, 08:17 PM   #958
sawpdx's Avatar
2014 Wildcat Max remote receiver location
I Just bought a 2014 Wilcat Maxx 5th wheel. I have a second remote control for the slides, awning, landing gear and I need to sync the remote to the receiving unit only problem is I don't know where the remote receiver is located. Any one here know it's location in the 5th wheel? Thanks in advance.
sawpdx is offline
Old 05-22-2015, 10:28 PM   #959
wwalker2984's Avatar
In my 2015 fifthwheel it is on the right side in the Storage area back wall just take three screws out of the bottom of the back wall at least that is where mine is
wwalker2984 is offline
Old 05-26-2015, 03:51 PM   #960
RAS
Dometic AC Return Air Filters
Rick,
I have a 2015 Wildcat 327CK with two AC units. Neither unit has AC filters in the return vents. This is a ducted system with two return vents in the bedroom and livingroom. The vents are screwed into the ceiling and there are no filters in them or anywhere else in the RV. I had the dealer look also. They are just as confused as some of the reps say it doesn't need filters and some say it does but didn't come with it. The vents are not made for constant filter replacement. I called Dometic and they emphatically state there should be filters there. I called the Forest River Customer Service and they reps do not know. All ACs that I know of need a filter. I also looked at another Wildcat different model and length and it also does not have filters in the ducts. Any ideas would be very helpful, thank you.
RAS is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
