Closed Thread
Old 05-26-2015, 04:40 PM   #961
Mr. Dan's Avatar
Originally Posted by RAS View Post
Rick,
I have a 2015 Wildcat 327CK with two AC units. Neither unit has AC filters in the return vents. This is a ducted system with two return vents in the bedroom and livingroom. The vents are screwed into the ceiling and there are no filters in them or anywhere else in the RV. I had the dealer look also. They are just as confused as some of the reps say it doesn't need filters and some say it does but didn't come with it. The vents are not made for constant filter replacement. I called Dometic and they emphatically state there should be filters there. I called the Forest River Customer Service and they reps do not know. All ACs that I know of need a filter. I also looked at another Wildcat different model and length and it also does not have filters in the ducts. Any ideas would be very helpful, thank you.
My '15 Wildcat has rudimentary filters in its 4 A/C return air vents.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Mr. Dan is offline
Old 05-29-2015, 10:02 AM   #962
Chris, is it possible to take the decals off the large windows on my Wildcat Maxx?
I am not sure the reason for putting across the center of the window but they ruin the view. I realize they are there to continue the decals on the rest of the Rv but I would rather have a clear view.
Charley Webb is offline
Old 05-29-2015, 11:45 AM   #963
Campfire Master
Chris isn't with us anymore. He's moved on to a different manufacturer.
I would try some heat and a razor blade. But, be careful with the heat. If you heat up just a portion on the pane, it will expand at a different rate that the unheated part. Then you will be looking for a new window. Something like WD40 should remove the leftover adhesive.
John
AVid is offline
Old 06-01-2015, 09:52 AM   #964
I used a razor blade then followed up with an adhesive remover (Goo Gone). Some came off really easy by just lifting a corner and pulling. Others required the razor blade. Why they applied them over the window is a mystery.
lddoty is offline
Old 07-28-2015, 02:49 PM   #965
"All in Good Time"
vnichols's Avatar
New wildcat 327ck. When I stored it and turned the battery disconnect "off", I noticed there is still power to the front & rear stabilized jacks & front cap lights. Is this normal? Is there a 2nd battery hidden somewhere ???
Vince in NC
Vince & Ulli
2016 Wildcat 327CK
2014 Ram 2500 Mega Cab 6.7 CTD 4x4
vnichols is offline
Old 07-28-2015, 04:19 PM   #966
2007 WildCat 32QBBS
05CrewDually's Avatar
Vince in NC
It's all in what they hooked through the switch. It sounds like they wired the landing gear direct to the battery.
When I put a disconnect switch in I wire it so it breaks the ground (- negative post) of the battery because it's usually one or two wires to do instead of 5 or more.
05CrewDually is offline
Old 07-31-2015, 12:46 PM   #967
Newbie.
monte0999's Avatar
Crack at bottom left where master slide meets camper.
Repaired it last year but recurred. Dealer mentioned that it has happened to a few of the Wildcats and gave me the name and email of the person to contact at your factory.
Apparently they have sent 2-3 of them back to the factory to be re enforced..... That master bedroom slide on the 2013 344qb is massive.
I have sent two sets of emails complete with photos back in May and June.
No reply as of yet but I am sure you guys are swamped. Camper still functions so no problem. Just would like a solution before I put it away in a warehouse for the winter.
2013 344 QBOK
2011 F250 4x4 Supercrew Diesel
monte0999 is offline
Old 08-23-2015, 03:56 PM   #968
2016 Wildcat 275ckx
Hi Chris,
Ordered a brand new 2016 Wildcat 275 ckx. Our very first trip it rained that night and the next morning we noticed water on the bedroom floor beneath the bedroom slide. The amount of water coming kept coming in long after the rain had stopped, in fact seem to increase, which leads me to believe it had accumulated somewhere and kept seeping in.
The tech thinks he has found the leak, something about they forgot to put silicone on the lower seal on the forward side. Didn't know there was silicone there. Hope this is not just a "patch" job, and in fact needs new seals. Anyway, assuming that this is fixed, do I need to be concerned about future ramifications--(rot, delamination, mold, etc.)
I can't begin to tell you how disappointing it is to factory order a brand new unit, wait 6 weeks for delivery, and then have water issues on very first night out due to defective slide. Don they not water test these slides?
Dan
Dan Perkins is offline
Old 08-26-2015, 03:50 PM   #969
Mr. Dan's Avatar
Originally Posted by Dan Perkins View Post
Hi Chris,
Dan
From a post above: "Chris isn't with us anymore. He's moved on to a different manufacturer. "
Mr. Dan is offline
Old 09-21-2015, 04:05 PM   #970
2003 27 rl
I have acquired a 03 27RL, I am interested to see if there is a blue print for the walls of this model. I need to do some water damage repair and would like to see if I can visualize what needs to be done before teardown.
rescfrmn is offline
Closed Thread
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat
