05-12-2012, 03:47 PM
#221
Originally Posted by rsjohnsn
Hi Chris,
I have a new 2013 344QB and noticed that the single A/C doesn't cool as well as I am used to. The unit is all the way in the back and it doesn't cool the front bedroom very well so I was wondering which unit do I need to purchase for the 2nd A/C option. Also would it use the same thermostat or a seperate one and if so where is the wiring located for it? I have found the 2nd A/C location in the front bedroom but not sure if it would connect to the duct work or if it would be a stand alone unit.
Scott Johnson
2013 Wildcat 344QB
I purchased a 2011 31T and have had the same problem. The dealer installed a 2nd AC in the front bedroom, which cools that room very well. However, unless your trailer is setup for dual zone it is extremely expensive to set up to run off 1 thermostat. I have Domestic Duo Therm as my second AC and it will cost about $540 to have a thermostat mounted on the wall in the bedroom. I hope this info helps.
05-14-2012, 07:50 PM
#222
We picked up our new wildcat fifth wheel and it only had one set of keys for the door, baggage doors, and storage compartments. Any ideas where we can get a second set of keys from?
The Green's
2008 Ford F-350
2012 Wildcat 313RE
Fast Eddy FEC 100 BBQ smoker
KCBS professional BBQ Team name "QueTPies BBQ Team"
3 kids, one dog
05-14-2012, 10:10 PM
#223
Lowes made my baggage door keys. Not sure about the door key.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-15-2012, 12:36 PM
#224
JAYCO Representative
Adding a 2nd AC to your Wildcat 344QB
Hi Chris,
Scott Johnson
2013 Wildcat 344QB
Your 344QB includes a forced option for 50 AMP service and 2nd AC prep. Your bedroom vent area is framed and pre-wired for a secondary AC unit of your choice -- talk to your Wildcat dealer about which options might work best. Some people opt for a lower profile unit in the 2nd location to keep the height down. You can also talk to them about the style of secondary AC control.
05-15-2012, 12:44 PM
#225
JENSEN technical support!
Originally Posted by rexerito
We just received our 312-BHX. When I connect my iPhone 4 to the Built in Jenson entertainment system and try and play a video, I get the following on screen message: "hdmi unsupport ipod video ,please change to cvbs"
What is cvbs? And how do I switch to it to watch downloaded videos?
Rex
The newest iPhones have a compatibility issue with digital video (but not audio) over the Jensen's HDMI connector -- it wants to use component video (CVBS) instead which you can do directly through the TV's component video inputs.
Please call Jensen directly for more assistance with this -- they're a great partner to Wildcat not only for their quality AV equipment but also their strong customer service:
Customer Service
Technical Support
Need JENSEN Customer Service? Click here to contact their Customer Service Team available Monday-Friday, 7:00am - 6:00pm Eastern Time.
Call 877-305-0445 for immediate Technical Support assistance.
05-16-2012, 10:41 AM
#226
Originally Posted by muzbomb
Hey Chris so i got the monitoring system figured out thanks to some helpful guys on here!!! I love this forum!!!! The only thing i am wondering about is
1. Is there away of sucking out of a jug or pail from the water pump?
2. When i kick the pump in i can hear it running but not getting nothing at the kitchen tap??
3. Why on a new camper would there be 2/3 Fresh water in tank, 1/3 Holding tank and grey empty?? Is this just from dealer testing system?
4. Is there 2 holding tanks cause i have 2 bathrooms??
Thanks Chris!!!
1. Yes. There is an inlet on the pump itself.
2. Are you sure the water is running through the pump? I don't have enough info to assist you with this...
3. Perhaps there was some leftover from testing/prep at the dealership. It did not leave the manufacturing facility that way...
4. On all Wildcats, there are 3 holding tanks (1 50gal black, 1 50gal gray for galley, and 1 50gal gray for bathroom) with an additional black tank on units with a 2nd toilet.
05-20-2012, 10:18 PM
#227
Chris,
This message is more a customer feedback kind of thing.
My wife and I love our 2005 27BHWB, and while we are not currently in the market we are looking in prep for a couple years from now. The 312BHX looks to be the only usable floor plan for us since we have 3 kids, and we really like the floor plan due to length and weight.
However, there are some things missing that we would really miss.
First, the Central trash system. That one is something almost all our fellow campers are jealous of as their trash cans are in the living space getting knocked around. It looks like that is not available.
Second, The hydraulic landing gear has me hooked and makes for a quick setup. I really dislike the wait for the electric jacks.
Third, is there a reason why there is no storage about the entire slide, seems all manufacturers including all FR products did away with this.
Even without these options, the trailer looks like a top contender if it's still available when we are ready to replace our existing unit. However, we do wonder why these features were eliminated or can they be added upon order?
Thanks,
Joel
05-21-2012, 07:44 PM
#228
Hi Chris, can you tell me how far the front landing gear on my 2010 27RL Wildcat extend, and if there is a warning label or paint strip that warn when full extension is near? Thanks
06-04-2012, 08:39 AM
#229
Wildcat 2002 model
I'm new at this. 27ft 2002 wildcat fifthwheel. while traveling side panel came loose and began rolling off befor i could stop. Findings- aprox. 2+ ft. of plywood deterioated. one side fiberclass torn aprox 3ft. Other side loose not torn but plywood rotten abt 2 ft back. HELP!!
06-04-2012, 08:29 PM
#230
i think you need to find a good RV shop. nothing the factory can do on a 11 year-old trailer. wouldn't be anything left that's warrantied.
the shop could contact the factory for parts.
06-05-2012, 05:31 AM
#231
I understand no warranty; Is there a known fix or is there a layout or print on the sides showing the supports ect. so we can tell where to repair to.
06-05-2012, 02:47 PM
#232
As recommended before, please see your nearest Wildcat or Forest River dealer for more assistance. They should be able to call in for anything they aren't familiar with!
06-05-2012, 03:15 PM
#233
Chris, We have a 2006 29 RLBS. Is the slideout frame made of wood or metal? The reason I ask is I have some delaminating in the corner of the living room slideout. I have found no leaks and with cabinets across the inside I see no water stains etc... On our trip last year we had a lot of condensation in the cabinets and especially in the area were the delaminating has taken place. Can you have delaminating without a leak? The delaminating is about 12 inches by 12 inches at the most. I did notice that the white covering on top of the slideout is not sticking anymore in that area(corner), but it is still attached and sealed good. Any ideas are welcomed.
Thanks, Tom
06-06-2012, 01:13 PM
#234
Thanks, Tom
Wildcat's slide rooms use the same 2" vacuum-bond lamination process as our sidewalls. While alumimum framing is used, there is also wood present in the build.
I would recommend seeing a reputable Wildcat or Forest River dealer to further assess the situation. Obviously, water and moisture of any kind is our enemy. Hopefully, they'll be able to find a solution for you.
06-15-2012, 03:52 AM
#235
Hey Chris,
Just received our Wildcat Sterling 32RK Wednesday and could not be more thrilled!!!! We do have a couple of questions - we did not receive the CatSense feature on our entry door - is it not available on the 2013 models? Also, does the TV in the main living area pull out and/or swivel? We also ordered the TV mounted in the bedroom- how does the bracket work there? We are looking so forward to camping this weekend in our new camper!!!!
06-15-2012, 03:42 PM
#236
Originally Posted by CampinQueen
Hey Chris,
I'm happy to hear you got your Wildcat! Please post a photo of it here or on our Facebook page when you have a chance. CatSense was discontinued before the model change -- I do not have an exact date. The TV in the main area of the 32RK does not pull out or swivel; it's attached with an "H" bracket to the wall. I'm unsure what bracket was used in your bedroom to mount the TV as that's not a factory standard or option, but I'll ask the production team next week!
06-15-2012, 10:31 PM
#237
Thanks Chris.....we are on our first camping trip in our new Sterling this weekend!!! Have not found a thing that disappoints us!!!
It's one great camper......love it!!
06-16-2012, 08:35 PM
#238
So Chris my husband now wants to know how to get to the back of the TV to attach our Dish Network receiver with an HDMI cable!! Thanks so much for your help AND patience.
06-16-2012, 09:00 PM
#239
To get the tv out, you just lift straight up. I had to remove our tv last week. The H bracket has upside down tear drop cuts in it that the tv slides down into. I found that if you give it a quick jerk upwards it comes right out as it is tight.
Bob
2012 Wildcat Sterling 29MK
2011 Chevy Silverado 3500HD LTZ 4x4 D/A
06-16-2012, 09:01 PM
#240
Where do we get a 2007 brochure? Our dealer is getting a used one and want to see floor plan before taking wife in to see.
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat |
