Old 01-21-2015, 07:57 PM   #1
Question Auto Leveling for Wildcat 312BHX or Other Xtralites?
Does anyone here have an auto leveling system on their Wildcat Xtralite? If so, which system do you have, is it hydraulic or electric, 4-point or 6-point, and how does it perform on fairly out of level ground (say up to 3 degrees or so)? I'm looking for a system powerful enough to safely take weight off the tires to the point where I could change a tire if I wanted to...similar to what you'd have on a Class A. Are any of the electric systems powerful enough to do this, or do I definitely need to look at a hydraulic system?
2014 Wildcat 312BHX
2015 Ford F350 4x4 King Ranch 6.7
ShadMan is offline   Reply With Quote
Old 01-26-2015, 05:03 PM   #2
Have the electric 6 point auto level system. Love it.
kssportsman is offline   Reply With Quote
Old 01-28-2015, 12:44 PM   #3
extremebike's Avatar
I have the Lippert 6 point. The motor is electric but the system uses hydraulic rams.
Yes it will work on out of level ground. If the site is outside the leg length the system retracts the legs and you get to put leveling pads or 2"x 12"under the foot to help with the leg length.
I've gotten used to it now so I can tell before I start (usually).
Yes the system will lift the whole rig off the ground or one side at a time. This happens on a side hill site where one side is higher than the other side of the trailer. Hope this helps.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 01-30-2015, 03:14 PM   #4
I have the Lippert level up and it works great. I wouldn't buy another camper without it.
Johnv is offline   Reply With Quote
Old 02-06-2015, 07:11 AM   #5
NOLE-FAN's Avatar
We have the 312BHX with the 4-point electric Lippert Ground Control....and it's fabulous. I think each jack is rated for 12,000 lbs and the system as a whole is rated to 20,000 lbs.
2015 Forest River Wildcat 312BHX
2015 Ford F-350 4x4 SRW SWB PSD
NOLE-FAN is offline   Reply With Quote
Old 02-17-2015, 11:52 PM   #6
duradiesel's Avatar
Smile
We have Wildcat Sterling with 6 point auto leveling. love it.
2006 GMC
2012 Wildcat Sterling
duradiesel is offline   Reply With Quote
Old 02-18-2015, 07:28 AM   #7
For those with a 6-point system, where did you buy it and have it installed? Camping World can only get a 4-point system, which they say is not designed to lift the trailer off the ground.
2014 Wildcat 312BHX
Old 02-18-2015, 07:27 PM   #8
duradiesel's Avatar
It came with the 5 th wheel . I bought the 5 th wheel used but it was factory installed.
Old 03-16-2015, 05:45 PM   #9
Nole-fan, did your come from the factory with it or did you add it on? We are ordering the brother of your trailer, the 312QBX, and I was thinking about the autolevel option.
jhpkmr is offline   Reply With Quote
Old 03-20-2015, 10:23 PM   #10
NOLE-FAN's Avatar
Ours was a factory option.....I'd definitely get the auto level.
312bhx, cat, leveling, wildcat
« Valance | HELP »
