Battery power issue
Hi All,
Having a weird issue with my 2006 Wild cat 31QBH. While NOT plugged into sure power I have do not have 12V power to the inside of the camper. Battery is good because I have power to the front jacks and can run the slide in and out with the switch mounted direct to the pump. They both are hardwired to the battery. Checked good for power on both sides of the quick disconnect. The convert is working when plugged into sure power as the lights and radio work fine. Nothing when unplugged from sure power. Checked for 12V at the fuse panel and found nothing. Is there a fuse between the battery and the 12v fuse panel? this is the only explanation that I can think of. Does anyone have a wiring diagram for this 5th wheel I can use? Or have any ideas where I can find the fuse between the battery and the 12v fuse panel?
Thanks,
Joel
