Old 07-09-2018, 09:22 PM   #1
Bedroom AC
We had dealer install a 2nd AC in bedroom as part of the sale. A dometic 13.5 K was installed, the thermostat seems to be built into it but does not shut off fan just cycles compressor when it reach temperature. Would like to see whole unit shut on and off instead of fan running all night long, is there anyway to install a
wall thermostat
fairpilot is offline   Reply With Quote
Old 07-10-2018, 04:40 PM   #2
wall thermostat
That's pretty much how they all work, constant fan when on. Hell they even run the AC and heat fan when in heat if you have 110.
nayther is offline   Reply With Quote
Old 07-10-2018, 05:00 PM   #3
I figured they were like self contained not sure why they would make it run continuously, ours does not have heat in it I believe just AC and fan, dial says says optional heat but does nothing. What are you saying about 110 volt?
Old 07-10-2018, 05:08 PM   #4
Coach
I'm not familiar with that set up, but if there is an energy saver mode, that should cycle the fan. I don't know if add on RV ac's have that or not.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-13-2018, 03:05 AM   #5
cavie's Avatar
Look at your unit and see if there is a fan auto setting. That will cycle your unit.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 07-13-2018, 03:22 AM   #6
Thurman's Avatar
"is there anyway to install a wall thermostat?" The bottom line answer is yes. Factory installed RV A/C units with t'stat are not different in operational design than an RV A/C unit without t'stat. The difference is that units with a wall mounted t'stat have a different electrical control box then a non wall t'stat unit. This box is mounted up in the A/C unit behind the Air Distribution Box, or ADB, which is the large plastic thing with the filter in it and vents for the cooled air to come out as in yours is. Can your new dealer mounted 13.5K A/C unit be converted to operate with a wall mounted t'stat so that the fan shuts down along with the compressor when the inside ambient air temp has been satisfied--yes it can, but it will be quite costly. First you would need a new ADB, then the control box, a wall mounted t'stat and additional wiring ran between the t'stat and A/C unit. Hiding these t'stat wires in the wall and ceiling is not easy at all but do-able.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 07-25-2018, 07:38 AM   #7
wall thermostat
When you cycle down on the thermostat you will see Auto, HI or LOW. Mine was on HI and I had the same problem as you but when I changed it to Auto it would shut off the whole system until it was time to start up again. Once you see HI use the arrow up or down to change it.
2012 Ram 2500 4X4 Short bed Diesel
2015 Wildcat 275 CK
lennyd96 is offline   Reply With Quote
Old 07-25-2018, 11:05 AM   #8
Mine does not have a thermostat , just knobs
bed, roo
