Old 10-16-2016, 04:15 PM   #1
Bedroom slide cracked
The bottom of our bedroom slide cracked and water dripped out. Dealer says it is a design flaw and FR says to put in a metal bracket to fix it with no intention of replacing the floor. They say they found the leak. Please help I do not believe what they are telling me. It is a 2015 wildcat 317rl. No water damage anywhere inside. I can't believe FR would not replace the floor.Click image for larger version
Name:	ImageUploadedByForest River Forums1476648880.377324.jpg
ID:	123135Click image for larger version
Name:	ImageUploadedByForest River Forums1476648897.329679.jpg
Robert
2012 RAM 3500 Cummins
Laramie Longhorn w/rambox
2015 Wildcat 317RL
Robert
2015 Wildcat 317RL
weldon182 is offline   Reply With Quote
Old 10-17-2016, 10:22 AM   #2
I retract my original frustration. Spoke directly to FR today apparently that metal bracket is the fix for my problem. I will post pictures when it gets repaired next spring. Sorry if I offended anyone with my original post. Just needed some clarification.
Robert
2015 Wildcat 317RL
Robert
2015 Wildcat 317RL
Old 10-17-2016, 06:44 PM   #3
Learjet's Avatar
I have the same unit.
I had water leaking at the aft window on the bedroom slide. The drain holes on the window did not drain the water that collects at the bottom, its a slide up type window. The window was defective. I elected to seal the window with black RTV to match the dark window and black frame, vs changing the window out or trying to drill the holes through. No problem for me, since i will never open that window anyway.
-2013 Ford F250 XLT 2wd Crew Cab 6.2 with 3.73
-2015 Wildcat 317RL
-B&W Patriot 18k, MorRyde, Timbrens
Learjet is online now   Reply With Quote
Old 10-17-2016, 06:56 PM   #4
Learjet
The dealer stated that some caulk was leaking on the top of the slide. However I have no confidence in them as I stated. I will check the window out when I pick it up though. I just couldn't believe they are not going to replace the floor. I also wonder how much water damage has been done I can't see. There is absolutely no sign of water damage on the inside which I find odd. We really love the coach and I want to take care of it thanks for the advise on the window.
Robert
2015 Wildcat 317RL
Robert
2015 Wildcat 317RL
bed, bedroom slide, crack, roo, slide
