Old 05-14-2013, 04:08 PM   #21
k52412's Avatar
Here is some pictures of my propane tank straps. I have 344qbh I hope they help.
Name:	2013-05-14 14.48.23.jpg
ID:	30491   Click image for larger version
Name:	2013-05-14 14.48.38.jpg
ID:	30492   Click image for larger version
Name:	2013-05-14 14.49.03.jpg
k52412 is offline   Reply With Quote
Old 05-14-2013, 04:10 PM   #22
Newbie.
monte0999's Avatar
Got it. The Hooked black end on the short strap doesn't hook on a pin. It hooks on the very end of the grey clasp. Push tank in all the way to give you enough slack. It's tight. Then hook the short black end on the tip of the grey clasp and fold it back over.
2013 344 QBOK
2011 F250 4x4 Supercrew Diesel
monte0999 is offline   Reply With Quote
Old 05-14-2013, 04:12 PM   #23
Newbie.
monte0999's Avatar
K52412's first pick shows it exactly. All you do from there is push the clasp over with his thumb.
2013 344 QBOK
Old 05-14-2013, 04:13 PM   #24
k52412's Avatar
Yep that is exactly it. Its vary tight in there but it fits.
Old 05-14-2013, 04:58 PM   #25
jevanb's Avatar
Originally Posted by jevanb View Post
wonder how to snap it closed then ???? I can figure out almost anything but this got me stumped........
I should be slapped I should of figured this out...thanks 344 guys
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-21-2013, 04:03 PM   #26
Newbie.
monte0999's Avatar
Boys, just got back from first weekend with the 'Cat. Everything went great. Only snag was with my slider hitch.
Was difficult to tell if it was fully locked in "tow"
Id pull the lever, feel it latch, and drive forward to find that the hitch wasn't Locked and it would slide back to the end of the rails.
Took me 4/5 attempts to get her locked and even then it didn't feel any different than the first times, just that it actually stayed where it was suppose to.
Is there something I'm missing here?
2013 344 QBOK
Old 05-21-2013, 06:56 PM   #27
jevanb's Avatar
I can just say superglide, you always know it is fwd... congrats on the first outing
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 06-01-2013, 10:48 PM   #28
Reference the factory propane straps = waste of time. Mine popped, leaving the hole opening larger then the pin size. There is no way to reset it as the pictures above show. I plan on re-doing both propane straps as a mod in the future. My thought was to modify a set of 1" cargo straps by cutting them down to size, then restitching them and mount them to the camper wall with a bolt/washer. To remove the tanks, just undo the ratchet and remove the tanks. Me personally, I will redo the locks on the propane doors as well. I will leave them unlocked when traveling (DOT reg?), but secure them when away from the campsite. Propane is to expensive to leave unsecured. :c)
Wylie Cyoti is offline   Reply With Quote
Old 06-09-2013, 08:10 AM   #29
Newbie.
monte0999's Avatar
Hey Edjunior, I installed the wireless airbag set up and it works perfectly. Just set your #and go.
Good call.
2013 344 QBOK
Old 06-09-2013, 08:37 AM   #30
Now a "Top Member"
EdJunior's Avatar
Cool Monte. Glad you like it. It sure is nice being able to just sit in the cab with no wires or hoses and adjust whenever it's needed. Have fun!
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
