Old 06-13-2017, 11:53 AM   #1
Best wheel bearing grease
Looking for a recommendation for the best wheel bearing grease for my 2012 Wildcat Sterling 32RL.
Anyone have a recommendation for something that comes in tubes for a small grease gun?
Roorider is offline   Reply With Quote
Old 06-13-2017, 12:02 PM   #2
Here's what Dexter recommends...
Hubs, Drums, Bearings
(scroll down for listing)
I use Mystic JT-6 #2
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 06-13-2017, 12:05 PM   #3
Retired
RubyDually's Avatar
I always look for NLGI 2 on the label.
This may help in your search.
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 06-13-2017, 12:15 PM   #4
Lucas Red-n-Tacky. Can find it anywhere (even WalMart). Been using it on my 32RL's wheel bearings and sidewinder hitch for almost 6 years. Good stuff.
Old 06-13-2017, 12:17 PM   #5
Too old to be too smart
SpringerPop's Avatar
Though I do not use it personally (Delo greases here), I have found that the best commonly-available grease for this purpose is the off-the-shelf Mobil 1 synthetic grease, found most everywhere.
NLGI #2, and rated GC/LB. Good drop point, and it's NOT molybdenum fortified (which I dislike for wheel bearings).
You can do a lot of research into, and find a lot of conjecture about, what is absolutely BEST, but Mobil has this pretty-well covered, and you can always find it locally.
It should get you to at least 99.5% of "THE BEST" (whatever that is).
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-13-2017, 12:24 PM   #6
Head Rambler
Red N Tacky here too, but as long as you follow Dexter's recommendation you won't go wrong. If you're adding grease to already greased hubs, you should probably call Dexter and ask specifically what they recommend. You don't want to mix incompatible greases in the hub.
Gotta go campin!
Old 06-13-2017, 12:29 PM   #7
jeff64's Avatar
X2 Good advise, check Dexter's specs. for the NGLI #2 greases. I also use the Mystic JT-6.
BUT, I'd recommend you clean out the old stuff 1st. The consistency of what was in there on my TT was way more runny than what the new JT-6 is and there was no water contamination of the old grease.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-13-2017, 01:46 PM   #8
Wheel bearing grease
Thanks to all the responders. I appreciate all of the info.
Old 06-14-2017, 02:20 PM   #9
CJ2
But we still don't know which is 'best'.
CJ2 is offline   Reply With Quote
Old 06-14-2017, 03:16 PM   #10
Kenny kustom's Avatar
X2 red n tacky
2017 Dynamax Isata 4
Old 06-14-2017, 03:49 PM   #11
Sure we do....It's the Mobile 1 Synthetic!.... (But only because that's also what I use....lol ) It's also the most expensive.
In reality, Any of these greases would do a good job. Just make sure you preload the bearings correctly, and don't mix greases unless you know the new and old greases use the same base stock.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 06-14-2017, 03:52 PM   #12
Herk7769's Avatar
I use this too.
HAM CALLSIGN - KC3FFW
Old 06-14-2017, 08:59 PM   #13
TimVWulp's Avatar
You need to be careful which type of grease you mix together. Dexter recommends that you use a lithium based complex grease. If you mix other types with lithium grease they may or will react with each other and cause the grease to fail. Many of the grease manufactures produce a lithium based grease you just need to make sure it's lithium based. If you can't find lithium based grease check with your local auto store.
I have attached a link from the site library at the top of this page. You will need to download the link and then open it. On page 21 you will find what Dexter recommends to use.
Google mixing greases you will learn what the grease manufactures have to say about doing this.
http://www.forestriverforums.com/for...?do=file&id=72
Hope this is helpful Tim
TimVWulp is offline   Reply With Quote
Old 06-14-2017, 09:57 PM   #14
cavie's Avatar
What ever is on sale!!!
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 06-14-2017, 11:47 PM   #15
TimVWulp's Avatar
Here is a link to a site that will explains what happens to mixed grease's.
Maintenance Tip: Never Mix Greases
Have Fun Tim
Old 06-15-2017, 02:45 AM   #16
I use green grease. way better specs then that red and tacky garbage... Just my opinion though..
compare
ball wear test .17mm vs .60mm
viscosity 120 vs 86
Base Fluid Viscosity CST 100 C 58 vs 18
Four Ball EP Test Weld Load kg 800 vs 315
etc etc etc
Green grease is all I use ever. bearings, front end, ect
http://www.greengrease.net/PDF/ggfac...2011_05_11.pdf
https://lucasoil.com/pdf/TDS_Red-Tacky-Grease.pdf
Lawrosa is offline   Reply With Quote
Old 06-15-2017, 06:14 PM   #17
Now a "Top Member"
EdJunior's Avatar
The best depends on whether the OP has a Chevy or a Ford (or Ram I guess), and/or a diesel or gas.
Okay, I'll stop. But it does show that like the aforementioned debates, grease has apparently as many answers. Good luck.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 06-15-2017, 06:27 PM   #18
Pop
X2
kamper00 is offline   Reply With Quote
Old 06-15-2017, 07:35 PM   #19
Yeah its even amazing how much better the green grease is then the mobile 1..
Mobil 1 Synthetic Grease ¬*
Old 06-15-2017, 09:58 PM   #20
Not being familiar with greengrease, I hit up ol' reliable BITOG.
Here's a thread that has some opinions:
https://www.bobistheoilguy.com/forum...Number=1624149
And more importantly:
https://bobistheoilguy.com/forums/ub...B?#Post4153891
Says not GC/LB rated, so wheel bearing use is questionable.
If referencing other forums is verboten, mods, please destroy, and send me a cyanide pill.
Pop
wheel
