Old 07-19-2018, 02:35 PM   #1
black water
we have a brand new wildcat maxx 285rkx, we went boondocking for a little over a week and i noticed on about the 4th day our bathroom gray water tank was full so i hooked a garden hose to the outlet to drain so out on the ground and it was black water, i thought mabye they mixed up labels on valves so i opened the black water valve and it was black water also so i have black water in both tanks. Has anyone else had this problem?
MinerDoug is offline   Reply With Quote
Old 07-20-2018, 08:29 AM   #2
SeaDog's Avatar
that sure seems strange my gray seems like black sometimes from the stuff (like coffee) I have put down the sink.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-21-2018, 01:43 AM   #3
I don't know how your rig is plumbed, but is it possible that the black water is leaking into the main dump pipe? (Have no idea of the correct terminology.)
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is online now   Reply With Quote
Old 08-07-2018, 01:25 AM   #4
Kitchen sink has a separate rear holding tank in my 2019 285rkx. Not sure whatís coming out of my front tanks yet. From experience I can tell you the valves were open from the factory. Not a fun time when I opened the cap to put the hose on to empty!!
Don
dongreg is offline   Reply With Quote
Old 09-15-2018, 11:58 AM   #5
Oaklevel's Avatar
Probably were left open at the dealer not the factory as the dealer is required to check the systems before the new owner receives the RV.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 09-15-2018, 12:17 PM   #6
Denver To Yuma In 90 Days
You do realize that dumping any sewer tanks on the ground is not the right thing to do...
Even when boondocking.
JohnD10 is offline   Reply With Quote
Old 09-15-2018, 06:27 PM   #7
cavie's Avatar
In neither situation did the OP intentionally dump black.
Many parks allow gray on the ground. mine is one of them.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-15-2018, 06:45 PM   #8
X2...it doesn't solve the OP's problem but even gray water shouldn't be dumped on the ground IMOP.
My suspicion, as another post suggests, the gray just looks black. I can't see black water flowing thru a garden hose without plugging with turds and turd tickets.
Hoyt is offline   Reply With Quote
Old 09-19-2018, 11:45 AM   #9
I would dump and flush both tanks.. then use a water hose and check what water comes out where, like putting hose in shower and see what tank it comes of....
rcrupper is offline   Reply With Quote
black, black water, water
