Old 08-24-2015, 09:49 PM   #11
Iwannacamp's Avatar
No one ever classified me as an expert.... It looks like the welded piece has been repaired. The tire seems to have more issues than bolt intrusion. It appears the tire is "scalloping" to me....but then I am looking on my phone.
I would look at that pretty close
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 08-24-2015, 10:09 PM   #12
The bolt isnt the problem. The upper channel is not straight. It has broken and been rewelded. This is causing the bolt to angle downward into the tire. I see a lot more work needing done than just cutting off a bolt.
mbrolin is offline   Reply With Quote
Old 08-24-2015, 10:13 PM   #13
Scubanut's Avatar
Yes x2 on that tire, that looks like a failure very soon.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 08-25-2015, 10:46 AM   #14
Agree with mbolin. Checked mine and the bolt is in the middle of the tires and pointed straight down. Something has caused yours to be at an angle. Good luck.
dmac1951 is offline   Reply With Quote
Old 08-25-2015, 11:14 AM   #15
Our friends, who were travelling with us to Alaska, had a similar problem with their Crusader that caused a blowout on the Alaska Highway. I would contact FR and tell them you have an extremely dangerous situation and need them to correct it. Also have them send you 4 new tires to replace the ones damaged by their bad design or lack of quality control.
Windjammin is offline   Reply With Quote
Old 08-25-2015, 11:27 AM   #16
I have a 2009 CC and I had to take it in for a slide adjustment. I didn't have your problem but they did notice that the brace had dropped. The dealer welded the brace back to it's original position and haven't had a problem since. I do believe a gusset was welded in. The 5er is in storage so I can't get a look at it.
Pipeman is offline   Reply With Quote
Old 08-25-2015, 01:31 PM   #17
Had that problem on my Windjammer it had just scuffed tire a little not cut it hacksaw solved problem!
walljammer is offline   Reply With Quote
Old 08-31-2015, 11:57 AM   #18
Commercial Member
Originally Posted by RoadCook View Post
Thanks guys. Here are some pics. My main concern is if anyone else had this problem & if there is or should be a recall. I know Forest River had a problem with getting recall info out to customers & this looks to me to be a serious safety hazard. Attachment 86743Attachment 86744Attachment 86745Attachment 86746
Having a part of the vehicle come in contact with a tire is definitely a safety hazard.
1. File a complaint with NHTSA
2. Contact FR and tell them you want them to fix the problem and replace the tire.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
2013, cat, slide, tire, wildcat, slide out
