Old 08-27-2018, 10:12 AM   #21
the electric heater element is powered by 110 vac. if you want to disable the electric heater element simply turn off the circuit breaker labelled 'WH'.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-27-2018, 12:34 PM   #22
OP is asking about "Tank Heaters" black, gray fresh.
Old 08-27-2018, 12:41 PM   #23
Originally Posted by nayther View Post
THAT'S IT! Finally got down on my hands and knees and found the switch, thanks all. Now if i can just figure out how they're feeding the tank heater power I'll be happy. I want to pull the fuse for them as I will probably never need them and don't want them accidentally turned on while boondocking.
check your 12-volt fuses. They may be on a circuit with something else. If you don't see a fuse labeled "Tank Heater", pull the switch out of the wall, put a voltmeter/light across the switch if it not lighted. You'll have to find a ground. Then go pull fuses. If something else stops working you'll know why.
Old 08-27-2018, 12:58 PM   #24
Mr. Dan's Avatar
there are no switches at the control panel or in the bathroom and I know it doesn't have one like my 1999 Wanderer had, that was a rocker switch right on the heater itself on the outside. I'll have to poke around more.
If I didn't have hot water I would have turned on the gas via the on/off toggle on the control panel, that controls gas only I'm pretty sure.
Not intending to kick a person while down... but the highlighted sentence gives evidence that's it's not helpful to be so definitive and incorrect simultaneously. It reduces the probability that other members can help.
Old 08-27-2018, 03:34 PM   #25
too true
nayther is offline   Reply With Quote
breaker
