Old 06-30-2018, 04:00 PM   #1
wwalker2984's Avatar
Broken studs
[ATTACH Click image for larger version
Has any one had this happen the studs broke off and I did not know it till someone was waving at and told me I lost a tire and I could not find it went to let Schwab and they installed new studs and clean my brakes and put my spare on and off I went and now Iím going to replace all the stats on all the axles Iíve never seen that happen ever and to top it off there was no damage to the trailer and this is a 2015 wildcat max I maybe have 10,000 miles on it
wwalker2984 is offline   Reply With Quote
Old 06-30-2018, 04:02 PM   #2
Who Dares, Wins
doc73's Avatar
Originally Posted by wwalker2984 View Post
[ATTACH Attachment 177853]177853[/ATTACH]
They can be damaged by over tightening, usually by impact guns. If they get loose lug nuts it can break them off due to the wobbling.
Since you lost them all I'd guess they were over tightened.
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-30-2018, 04:08 PM   #3
The bad thing is not five minutes before that happened I adjusted my mirrors to look at my tires and wheels on the passenger side and the driver side and everything looked good
Old 06-30-2018, 04:27 PM   #4
Did you happen to have just had bearings packed or brakes checked or tires balanced ? When all studs shear off itís usually from over tightening with impact gun.
Decon Blue is offline   Reply With Quote
Old 06-30-2018, 05:59 PM   #5
onetonford's Avatar
When you get a chance change the other tire I had one tire shred and after I had it replaced used the trailer several more times before I noticed the other tire was deformed possibly from running on 1 tire for several miles.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-30-2018, 07:28 PM   #6
I've never had a stud break from over tightening unless it was ridiculously over tightened. My bet is the wheels were loose. Just my opinion.
Jeff
bigmurph is offline   Reply With Quote
Old 06-30-2018, 09:20 PM   #7
No the wheel has never been off from when I brought it home in 2014
Old 06-30-2018, 10:08 PM   #8
Scoundrel
HangDiver's Avatar
X2^^^^ What he said.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 06-30-2018, 11:11 PM   #9
I am pulling all the tires and replacing all the studs and have a new rim to match the other ones because I am going to Zion from California in October and have other trips close by and will Carrie six extra studs With lug nuts
Old 07-01-2018, 01:28 AM   #10
Just a member
kandl's Avatar
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge Ram 3500
kandl is offline   Reply With Quote
Old 07-01-2018, 04:46 AM   #11
We can all WAG on what caused the Stud Issue but the Only way to know for Sure is "Find the Wheel and do a CSI"! Never been Off since 2014= Youroo!!
Old 07-01-2018, 08:47 AM   #12
Who Dares, Wins
doc73's Avatar
Right...
2015 ChevyHD D-Max
Old 07-01-2018, 12:18 PM   #13
When the trailer was at less swab getting repaired up-and-down the highway I could not find
Old 07-01-2018, 12:59 PM   #14
Jeff
There are impact wrenches in use today to tighten wheel lug nuts capable of producing up to 1,000 ft lbs of torque. In the hands of a beginner they are more than capable of breaking studs, or at least starting the cracks that lead to total failure.
Another issue. Steel wheels have "coined" centers. As the lug nut is tightened the wheel center acts like a belleville washer. It collapses as torque is increased adding tension. This is more forgiving than with cast aluminum wheels where there is no "spring". As the lug nut is torqued tension is created in the stud but since there is no "spring" in the wheel center you can go from proper torque and ideal tension to excessive tension and fracture lines.
Ford has this problem with their F 450 and larger chassis for a while. Wheels had flat centers and nut had a flat washer attached. Only took about 1/2 turn too much to go from max torque to fracturing the stud.
The tire stores I patronize use impact wrenches to remove lugs and to run them back on until they are just a little more than finger tight. The finish work is then done with a torque wrench. The proper way. Factory production often rushes things and there are no torque wrenches involved,
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
« lead time | radio »
