Old 07-12-2017, 08:07 PM   #1
campingbaba's Avatar
Cable tv
We have a 2017 Wildcat 327 RE and the only cable connection that works is the bedroom one . The dealer has checked that the wires are good and has changed the antena booster . The only way to get tv in the living room is to connect a splitter in the bedroom and run a cable from the bedroom . Any ideas would be great .
campingbaba is offline   Reply With Quote
Old 07-14-2017, 07:21 AM   #2
cavie's Avatar
My '02 27' RK works Main line to the living room and a spliter to the bedroom. Look behind the living room tv for cable connections.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 09-13-2017, 06:54 PM   #3
My 2015 327 ck has two SAT connections and one cable connection. They all work well but the living area SAT is labeled number 2 with the bedroom being number 1.
whj77372 is offline   Reply With Quote
Old 09-13-2017, 07:13 PM   #4
SlowrideHD's Avatar
Do you have a small cable connection plate maybe in a cupboard close to your living room tv? I'm not familiar with your layout. But on my living room tv, there is a small button on that cable connector plate that when pushed activates a powered booster/splitter (I'm not sure if my terminology is correct) and a little red LED light will be either on or off. When it is on (or off) can't remember which, but one way the cable connection works and the other way the roof antenna sends the signal to the living room tv. My connector plate is way back at the back of a cupboard next to the tv compartment.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is online now   Reply With Quote
Old 09-13-2017, 07:47 PM   #5
Turn that Booster off for cable, on for antenna. You also have to move the tv cable to the other terminal on the wall plate. You will then need to do a channel search for cable channels on the TV.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
CedarCreekWoody is offline   Reply With Quote
cable
