Old 06-23-2019, 06:01 PM   #1
Can't operate slide out with remote
On my 2014 Wildcat Maxx 27RLS I have not been able to operate my slide out using my hand held remote. I can operate everything else with that remote except the slide. I can operate the slide using the manual interior switch just fine. This problem is recent as I have always been able to operate the slide using the remote. I have looked high & low trying to find where the receiver for the remote control system is, but have been unsuccessful as of yet. I looked behind the interior control panel and inside the cabinet where the main electrical panel and the converter is located, but nothing! I figured that there may be a fuse in the circuitry at or near the receiver / control for the remote that may be blown. But I have to find that receiver first. By the way, I also checked all the 12 volt fuses in the main panel and none are blown.
Might anyone know where that receiver is located? Any help would be much appreciated!
Sbosserman is offline   Reply With Quote
Old 06-23-2019, 08:40 PM   #2
i do not know where it is on your unit. many people have reported them in the craziest places. we have a lippert level up system on our trailer that shares a common pump between the legs and the slides. the receiver is mounted upside down on the roof of the battery compartment over the pump mechanism. you've got to get on your hands and knees to find it. other than that i can't give you any more advice. but if you share a common pump look real good around it.
on a social side we have been through lodi several times in the last couple of months. my wife's son lives in valley springs and had an illness. we went over a couple of times to care for him. we took the trailer and stayed at commanche lake (very impressive place)! we also got to fly into and out of the stockton airport a couple of times. not an impressive place! but the orchards and vineyards were beautiful all around the area.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 06-23-2019, 10:45 PM   #3
I have 2018 WCF262RGX-OR. On this unit the receiver for the remote is in the basement. Looking in the right side door the receiver is on the left behind the panel. Four screw to remove panel.
joespring is offline   Reply With Quote
Old 06-24-2019, 09:40 AM   #4
Approximately how big is the receiver box? Does it have any fuses located on or near it?
Thanks for the info!
Old 06-24-2019, 09:43 AM   #5
ours is maybe 10 or 12 inches by 8 or 10 inches. yes it has a fuse on it for the slides. ours also has fuses for the awning and the porch light.
Old 06-24-2019, 12:04 PM   #6
Head Rambler
A couple of people have posted in the Where is Your Remote Receiver/Hub thread that their Wildcat Maxx's receiver was "in pass through behind vanity panel on passenger side." maybe that's where yours is.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-24-2019, 12:39 PM   #7
On my Wildwood 27RLSS the fuse panel for the remote is under the kitchen sink.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 06-24-2019, 02:21 PM   #8
Thanks for everyone's replies. I have looked in the storage compartment, there is no access available to open on either side. I've looked under the kitchen sink in all areas and nothing, inside the water heater compartment there is nothing. I called Forest River and they said to look under the stereo unit. So I pulled it out and there is nothing under or at either side of that unit. I also looked in the sealed area under the oven range, nothing. Then they said to look under the sofa kick panel. Well, my sofa is pull out drawer that has the inflatable bed and there is nothing behind that. So, Forest River is going to call me back after the tech contacts the production manager in Oregon to find out where they installed the remote control panel in my specific serial number trailer. Waiting for their call back now....
Old 06-24-2019, 03:04 PM   #9
Blog: RVroadtripper.com
hbillsmith's Avatar
2016 295rsx with LCI Ground Control 3
If I open the front storage bin (the one that has the battery and front lift legs) and look up above my head in the compartment, that's where I see the controller panel and the wire antenna. You may just need to make sure the remote is fully charged and then go thru the repairing sequence. This YouTube has the instructions How to Program and Pair LCI remote
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 06-24-2019, 03:33 PM   #10
I appreciate the info, but the control that I am referring to is NOT the LCI leveling system which was the you tube link that you sent me. My control is the remote that controls the slide out, the awning, the front & rear electric stabilizers and the porch light.
I did just look inside my storage compartment and there is no control unit on the ceiling or walls inside that area nor is there any access opening in my storage area. The control unit is NOT behind the carpeted cover in the storage area.
I am still waiting for Forest River to call me back with that location as it is not in any of the areas where the techs said it usually is. UGH!
remote, slide, slide out
