Old 01-19-2019, 01:39 PM   #1
Ceiling fan quit
The ceiling fan in my 2006 Wildcat has quit. Looks like motor is shot. Any one replaced their fan or motor? Where did you get it ?
Rick F is offline   Reply With Quote
Old 01-19-2019, 01:46 PM   #2
Mr. Dan's Avatar
Mine hasn't quit but if I were sure it quit and didn't just have a wire loose, I'd go to Lowe's or other home store and get a like-sized replacement.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 01-19-2019, 02:40 PM   #3
Sadly in our throw away society just replacing it is probably easier and cheaper, and probably get a better fan then what ever was factory installed.
Kimber45 is offline   Reply With Quote
Old 01-20-2019, 05:17 PM   #4
It's likely to be a 12 vdc motor. Once you pull it down you will be able to find a brand name and be able to google it. I installed one in my 5th wheel. They come in two different blade sizes but the same motor.
Parrott_head is offline   Reply With Quote
Old 01-20-2019, 05:20 PM   #5
Mr. Dan's Avatar
Mine is 110v AC.
Old 01-20-2019, 05:20 PM   #6
the fan in my unit is 110 volt only, guess that is the first place to start on your decision on what to do.
Old 01-21-2019, 02:14 PM   #7
Mine is definitely 12v. Guess i will have to take apart and see if any mfg info is on the motor.....Thanks
Old 01-21-2019, 02:35 PM   #8
Mr. Dan's Avatar
If it's 12v DC, there's a fuse somewhere. Check it.
Old 01-30-2019, 02:53 PM   #9
Fixed fan
After reading many posts about fan problems, I decided to order a new wall switch. Installed it and fan runs as it should 😜😜
Old 01-30-2019, 02:58 PM   #10
Mr. Dan's Avatar
Good for you.
Thanks for returning to post your findings!
Old 01-30-2019, 03:33 PM   #11
win
win's Avatar
I took mine apart and found one of the magnets let loose, used gorilla glue lol, its been 4 years
win is offline   Reply With Quote
fan
