Old 09-14-2019, 03:40 PM   #1
City water connection
When we hook up our 2016 262 RGX to city water connection it fills up our freshwater holding tank any ideas?
julieg is offline   Reply With Quote
Old 09-14-2019, 03:43 PM   #2
cboss's Avatar
Check your winterization valve positions.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is online now   Reply With Quote
Old 09-14-2019, 04:11 PM   #3
Mr. Dan's Avatar
It's a common problem... reported here weekly. It generally has nothing to do with winterizing valve. It's usually related to the water pump's internal check valve. Read all the posts and external links in this thread ==> Water issues - overflowing fresh water tank.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-14-2019, 04:19 PM   #4
Perfect.... thank you. Winterization valve positions fine weíll just install a bypass valve. Seems like itís always something. Thisíll be an easy fix at least.
Old 09-14-2019, 04:23 PM   #5
Mr. Dan's Avatar
"Check valve"
Old 09-14-2019, 05:17 PM   #6
Originally Posted by Mr. Dan View Post
"Check valve"
ID:	214975sorry saw this one and figured weíd try it.... thought this was bypass. Anyways drained freshwater system and hot water heater completely 2 times and now itís not filling up the holding tank nor is any water leaking..... I told my husband Iíll only charge him $125 for my services today!
Old 09-14-2019, 05:23 PM   #7
Mr. Dan's Avatar
Attachment 214975sorry saw this one and figured weíd try it.... thought this was bypass. Anyways drained freshwater system and hot water heater completely 2 times and now itís not filling up the holding tank nor is any water leaking..... I told my husband Iíll only charge him $125 for my services today!
You let him off light.
I prefer an inline check valve (although I havenít needed one) because it allows water to flow in only one direction so you donít have to remember to open/close anything. Whatever works best for you.
Old 09-14-2019, 05:29 PM   #8
Well like I said after completing draining the water and air from the system a couple of times itís working as designed.... keeping fingers crossed it stays that way. Thank you for your help.... much appreciated
city water, water, water connection
