Old 08-09-2014, 06:39 PM   #1
grcooper's Avatar
Coating under slide
Noticed a scratch/cut in the coating under the bedroom slide. Checking further I found a screw behind the bottom seal, apparently left behind during construction.
Any suggestion on what to use to paint/seal this material?
Name:	ImageUploadedByForest River Forums1407627567.308447.jpg
grcooper is offline   Reply With Quote
Old 08-10-2014, 04:39 PM   #2
RSchleder's Avatar
That's a really good question! It's a shame it even had to happen--but, it is what it is. I imagine there's several different types of sealant that could be used here. I think I would buy some clear silastic (tube) and put a couple of beads right down the center if the tear. I'd then use about 1" wide metal or plastic spatula to spread out/smooth the beads into the material. This should, after it dries, give you a good strong, flexible repair that should last for years.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 08-10-2014, 05:10 PM   #3
Eternabond
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 08-12-2014, 08:23 PM   #4
grcooper's Avatar
Thanks for all the help. Found some stuff called Squim (used for belly coat). Worked great.
Old 08-12-2014, 09:04 PM   #5
Salt Shaker's Avatar
I am not familiar with squim...what is it?
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 08-12-2014, 09:16 PM   #6
grcooper's Avatar
It is a tape with adhesive on one side, made from the same material as the underside of slide. The RV shop called it Squim.
Old 08-12-2014, 09:19 PM   #7
Platokidd's Avatar
Looks like that could be darco on the bottom of that slide-out.
Darco tape may work for you.(underbelly tape)
Do you have any links to Squim... I cant find it on line.
Here a link that you may find a good read.
Slide out /Underside wearing
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 08-12-2014, 09:22 PM   #8
grcooper's Avatar
Picture of what I used. Click image for larger version
Name:	ImageUploadedByForest River Forums1407896564.155516.jpg
Old 08-12-2014, 09:36 PM   #9
kerrlakelover's Avatar
I echo Platokidd, do you have any info on where we can find the "squim"?...retailer, website......
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 08-12-2014, 09:43 PM   #10
grcooper's Avatar
I found it at Skipanon Marine & RV Supply
69 NE Heron Ave, Warrenton, OR
(503) 861-3626
slide
