I'm trying to locate my converter on my Wildcat 5th Wheel. I'm having issue with charging the battery. I was told there is a re-set button on the converter but I need to know where converter is located. Thanks for any assistance.
I have found most RV's the converter is found within a few feet of where the power cord comes into the RV. Also it is right at where your fuse and breaker panel is located in the RV. Also depending on your converter brand it may have a fuse instead of a reset button I know mine doesn't have one it is fused.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
On many...you have to remove the front cover of the breaker box and you'll find the converter tucked away on the bottom of the box.
It is not hidden. It will be in the interior of the coach. About 8 x 12 is size. Mine is not near the electric cord entrance. Mine is next to the furnace under the pantry, all the circuit breakers for 110 volt and 12-volt fuses are contained in it. Mine is brown in color and has vented door. It is on the floor. They are place all over depending on floor plan.
it is behind the breaker box, you have to remove the cover and then pull the box out. I have done this on my 317RL to install my PI EMS unit Everyone else is guessing
