Old 08-02-2015, 08:18 PM   #11
onetonford's Avatar
Mine had the switch go bad and it was only a few months old they put it where the rear wheel would throw water and road dirt right on it took a old folgers coffe plastic jar they are a square shape cut a hole the size of the switch and mounted it and silicone it to the side with the round opening down the screw cap can be used for access. so far no more problems. Just remembered that mine also had a fuse by the motor at the wire connection.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-02-2015, 09:23 PM   #12
There are 2 switches.... One for each side and neither are working????
sears532 is offline   Reply With Quote
Old 08-03-2015, 10:23 AM   #13
5er_tom's Avatar
One of mine would not go down. I used a socket wrench to manually lower it a few inches. Then it worked okay. I am now careful to not retract it too far.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 08-03-2015, 10:33 AM   #14
Timex's Avatar
Can you confirm there is power at the switch?
In other words, if you were to press the EXTEND or RETRACT button, does the motor try to make any noise?
If no noise, you will have to take the screws that hold the switch to the wall, and with a multimeter, check to see if power is getting to the switch.
If no power, go to the fuse box(probably near/with the converter) and figure out if the fuses are good.
Don't trust the red lights on the fuse box that show shorted fuses. Take them out and visually check them.
Let me ask, is there anything else in the camper that doesn't work(electrically), like the refridge, AC, outlets...?
Is the coach battery fully charged?
Is there a battery disconnect turned on?
Check the 2 reverse polarity fuses(big usually orange says 40 on them).
If all these things check ok, I'd look at a bad switch then.
BUT, I highly doubt that 2 switches went bad at the same time.
With my foot remedy, I actually kinda stomped it while pressing the button.
Go do these checks and get back with us.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 08-03-2015, 05:56 PM   #15
On our last trip we have had the same problem on our Salem Hemishere 263RL. Rear works just fine but the front will not retract. Pulled into a small local RV repair shop and he check ours out quickly. Bad switch. Trip into the dealer next week to replace under warranty as well a recall on our hubs.😔
2010 Ford F-150, 3.55 Quad Cab
Micanopy, Fl
80gator is offline   Reply With Quote
electric, stabilizers
