Old 08-02-2015, 05:47 PM   #1
Electric rear stabilizers
Just finished shakedown #1.... Only real issue is the rear stabilizers would not lower when we first go there and have no worked since..... Came up ok when we left but now seem to not have power.... No fuses or breakers thrown.... Is there an in line fuse I am missing
2016 Wildcat 312bhx
sears532 is offline   Reply With Quote
Old 08-02-2015, 05:52 PM   #2
Timex's Avatar
They might be jammed (for lack of a better word) in the up position. Try pressing down with a foot while holding the EXTEND button.
Mine did that 1 time and this was my remedy.
Some would say that you might have over retracted them when you raised them last.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 08-02-2015, 06:10 PM   #3
mduff's Avatar
We had the opposite direction. Replaced the switch and all good. The switch on a Wildwood is quite exposed and especially the rear getting road grit thrown up against it. We carry a spare switch, and have a Lippert remote option that allows us to operate the stabilizers.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 08-02-2015, 06:18 PM   #4
fonzie's Avatar
Check visually for burnt fuse in distribution panel, do not rely on red led light next to it.....
Fonzie
Old 08-02-2015, 07:01 PM   #5
I have now tried the pressure technique.... That did not work.... So going to others
Old 08-02-2015, 07:02 PM   #6
It is brand new... Would hope switches not out yet but will check that too as well as the fuses again
Old 08-02-2015, 07:18 PM   #7
dannyabear's Avatar
There is probably an external fuse under the tongue near the battery.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 08-02-2015, 07:19 PM   #8
Timex's Avatar
I put a cover over my switches.
If the pressure/foot test didn't work, on to the fuse box...
Old 08-02-2015, 07:38 PM   #9
I like the cover idea.... Once working again will add that
Old 08-02-2015, 07:52 PM   #10
Georgia Frog Rally 2018
aceinspp's Avatar
I would check the switch. Maybe defective or just a loose wire. Later RJd
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
electric, stabilizers
