Old 07-09-2013, 05:20 PM   #1
fifth wheel hitch height
I recently purchased a 312bhx. can anyone tell me what the level hitch height is of the fifth wheel king pin. i want to use a gooseneck adapter and am looking for what length i need. tow vehicle is a 2010 dodge ram 8 ft bed cummins.
rem12para is offline   Reply With Quote
Old 07-10-2013, 08:26 AM   #2
Fulltime family RVer
I could be wrong as I'm repeating what I've read on the Internet - but "they" claim the gooseneck adapter will void your frame warranty.
Interestingly though- the campground that I'm in now have 2 gooseneck adapters.
ependydad is online now   Reply With Quote
Old 07-10-2013, 08:27 AM   #3
"They" also say that most fifth wheel frames aren't near beefy enough for the extra forces from gooseneck adapters and you're fixing for problems if you do it.
Sorry, neither of these answer your actual question, though... I don't know that.
Old 07-10-2013, 08:42 AM   #4
Send a message via MSN to Tiggerdad
Good point. You can read many horror stories of frame/pin box failures on the internet. It appears that most are barely adequate for conventional towing. Goose necks change the leverage point and creates higher stress points on the frame.
Even if the manufacturer approves it, I wouldn't do it. After one year, they are off the hook for any warranty.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 07-10-2013, 09:48 AM   #5
rbcdp98's Avatar
Some ware in the 6-10 inches from bed rail to the over hang is what I've been told. Mine is at 7 inches. I would not suggest a gooseneck adapter I have seen first hand the problems these have caused.
rbcdp98 is offline   Reply With Quote
Old 07-10-2013, 09:51 AM   #6
You are asking for BIG PROBLEMS. Best advice is DON'T DO IT!
Old 07-11-2013, 06:52 PM   #7
If you want to go the gooseneck adapter, may I suggest the Anderson ultimate goose neck adapter. ( I know guys, ready for the slams). I have been using one for over a year now and the more I use it, the more I like it. I cannot see where it adds additional stress to the the trailer as the leverage spot is about the same as a fifth wheel with the exception that it rotates on a ball instead of a pin. I did contact Libbert and they state it will void the warranty, however they would have to prove the hitch caused the problem. Anderson will warranty your trailer if any damage is proved to be caused by the adapter ( I have that in writing). This warranty has never been tested that I know of. More and more dealers are now selling these, and actually recommend them, rated to somewhere around 24,000 pounds.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 07-11-2013, 07:01 PM   #8
racerx, it adds an approx. 2' longer lever arm on the pin box. Don't think it would take much to prove it caused the failure.
Old 07-11-2013, 07:13 PM   #9
Oldcoot,
The ball, when seated, is no lower then the pin itself and may even be closer to the box. The adapter can be mounted to where it is actually closer to the trailer, creating less required stress on the pin box.
Old 07-11-2013, 07:27 PM   #10
Oldcoot,
Did you mean to say 2ft. or two inches?
