Old 12-11-2014, 01:49 PM   #1
wwalker2984's Avatar
Filling the fresh water tank
I filled my fresh water tank or I think i did filled it real slow water started to come out the vent . Ck the gage it said 1/3 so I think oh the gage is not working . Now this is the FRIST time out in my new 262 RGX wildcat max so I think I will have lots of water it's got a big tank well I ran out of water by the next day and only two of us in the fifth wheel the gray and black didn't have munch in them so has any one Else have this problem?
wwalker2984 is offline   Reply With Quote
Old 12-11-2014, 03:03 PM   #2
Kaadk's Avatar
I've found that no matter how slow I fill, sometimes I still need to 'burb' the tank. I.e. I wait for it to settle down and then start filling it again. Kind of like how you do when feeding an infant.
Also, you said this is your first trip. Did you have water in the lines and/or the hot water tank before you started? Might have taken quite a bit out of your fresh water tank just to fill those.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 12-11-2014, 03:09 PM   #3
Yes there was water in the hot water heater and the lines well now that Iam home I will try to put more water in it and see if will take any more. Thanks just don't have time to take it back to the dealer its two hours a way from home and another trip is already for January
Old 12-11-2014, 03:43 PM   #4
WFD
There's nothing wrong with your trailer....your gauge is likely bang on if you ran out of water in one day...when filling the fresh water tank they do tend to burp like that. What you need is one of the very inexpensive water fillers...it screws onto the end of your water hose, has a valve on it and a long piece of tubing on it that allows you stick it a little ways down the throat of your filler. Once I got one of those my problems were solved. They cost under $10....if I knew how to attach a link I would, but go to Amazon, put RV water tank filler in the search and the Camco 40003 will come up...thats the exact one I use.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 12-11-2014, 03:50 PM   #5
Ok Thanks I will look in to that
Old 12-12-2014, 11:31 AM   #6
Dave Lyon's Avatar
X2
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is online now   Reply With Quote
Old 12-12-2014, 12:04 PM   #7
Originally Posted by Dave Lyon View Post
X2
X3
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 12-12-2014, 12:43 PM   #8
mattb's Avatar
X4, plus turn on your pump while filling, to fill the hw tank, otherwise you pull those gallons right off when you are setting up.
mattb is offline   Reply With Quote
Old 12-12-2014, 12:47 PM   #9
Yes I all ways turn on pump be for I leave the house and turn on the hot water heater on to ck for leaks and things I will try the water fill hose this weekend and let you all know if it works Thanks
Old 12-12-2014, 02:05 PM   #10
offroad's Avatar
Here is the Camco 40003 water filler, I agree it works well.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
fresh water, tank, water, water tank
