Old 09-18-2018, 10:11 AM   #1
Forest River Wildcat Tires
Hello, I been having a problem with tires they only hold up for a year. Tires are what manufacturer recommend. I have had 4 5th wheels in the past and never had this problem before. Has anyone else had this problem? Does anyone have a revolution to this issue? please let me know.
Garr is offline   Reply With Quote
Old 09-18-2018, 10:36 AM   #2
Out of Order
What tires are you running. What make/model and Load Range??
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
todtc318 is offline   Reply With Quote
Old 09-18-2018, 10:43 AM   #3
SilverbackMel's Avatar
Do you take care of them; ie: balanced, right pressure, cover them when not in use over extended time, avoid hitting curbs, avoid pot hole roads, and so forth. Stuff can still happen, however, some careful attention can help avoid a bad situation.
SilverbackMel is offline   Reply With Quote
Old 09-18-2018, 10:43 AM   #4
Mr. Dan's Avatar
... and what Wildcat do you have?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-18-2018, 10:48 AM   #5
Could be as simple as your axles being out of alignment or your frame not being built true.
Another thing you can consider if you have the "space" is upping your wheel size by one inch and installing equal or heavier load rating truck tires.
TranceX2 is offline   Reply With Quote
Old 09-18-2018, 10:53 AM   #6
wmtire's Avatar
The site team has merged duplicate identical threads and deleted another. As per the site guidelines:
http://www.forestriverforums.com/for...ork&page=rules
Please: Do not post the same discussion topic more than once or in several areas of the forum as this makes it difficult for others to help or follow the converation.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 09-18-2018, 12:11 PM   #7
Forest River Tires
I had a number of problems with the tires on my Wildwood. After over $9,000 damages payable by both my insurance company and me, I found that the axles on the trailer were not properly aligned. Soo...if you're having tire problems on a new rig, I suggest you find a good axle shop and have those axles check for alignment.
JimMorrell is offline   Reply With Quote
Old 09-18-2018, 01:13 PM   #8
X2-- makes since if all of a sudden you have new 5er and having tire issues.
ard58 is offline   Reply With Quote
Old 09-18-2018, 03:31 PM   #9
I had a 2002 27RK Wildcat that kept wearing tires on one side. In 2007 I took it to Crump Truck and Trailer Works at Springfield, Mo. They aligned the axles and no more uneven wear on the tires for the next 7 years when I traded for a new camper.
glcall is offline   Reply With Quote
Old 09-18-2018, 09:49 PM   #10
Are you traveling within the maximum speed rating of your tires? If not then that may be your issue.
rayham7777777 is offline   Reply With Quote
Old 09-19-2018, 06:26 PM   #11
St 225/75r15
8ply load d towmax str11
air pressure 65lbs 1500 miles on them
they continue to blow out. Purchase 1 1/2 years ago.
Trailer specs the same.
Old 09-19-2018, 07:45 PM   #12
onetonford's Avatar
I just changed out my Transmasters (greenball tire company) 225 75r 15 D 8ply with Maxxis 8008 225 75r 15 E 10ply as the old tires were 9years old. No wear but two tires were separating and I decided to get them all changed out. Kept the spare that is a Hi-Run 225 75r 15d it looks identical to the Maxxis thread and sidewalls.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 09-24-2018, 08:31 AM   #13
I agree with other that axle alignment is contributing to your issue. I travel from Florida to Minnesota each year and have had my share or tire issues. My rear axle was bent or sprung causing inside edge of tires abnormal wear. I now travel with empty water and holding tanks. I always carry two new spares. Tire pressure monitors a must, I had two flats this past trip (nails in tire) both caught in time by TPMS. I buy the best American made tires I can find. I never drive faster than 62 mph. I also discovered that tires wear much faster at freeway speeds when outside temps are above 90.
RML850 is offline   Reply With Quote
Old 09-24-2018, 08:50 AM   #14
Denver To Yuma In 90 Days
Originally Posted by Garr View Post
St 225/75r15
You said it right there...TowMax tires!
These are widely known as 'BlowMax' tires in the world of RV owners.
Do not ever buy another BlowMax tire!
Sounds like you have 'D' range tires right now...
Upgrade them to 'E' series tires (check wheels first to see if they can handle 80 PSI instead of 65 PSI).
As had been mentioned already, the Maxxis 8008's are good, the Carlisle tireshave a pretty decent track record, the new Goodyear Endurance (NOT the Goodyear Marathons, which are junk tires), and the Hercules SP2's (which I have) are good as well.
JohnD10 is offline   Reply With Quote
Old 11-01-2018, 10:17 AM   #15
wde
Life long camper
wde's Avatar
Towmax is terrible
I am currently having repairs done to my 2017 Wildcat due to a blow out of one of the Towmax tires.(OEM tires)
The tire completely seperated while travling 60 mph on an interstate highway.
Tire pressure was correct as monitored by my TPMS at the time of the failure.(complete tread seperation)
No coverage by the tire manufacturer at all.
Incident did $3200 in damage to the camper.
Looking at Goodyear Endurance or Maxxis tires and going up to 16 inch rims and tires.
Pretty upset with Forest River and Towmax !!
wde is offline   Reply With Quote
Old 11-01-2018, 12:44 PM   #16
Wildcat Tires
I blew an OEM tire at 1,200 miles with about $7,000 damage. After the second blowout, I bought new Hercules tires as recommended by my local Firestone dealer. He had Hercules on his 5th wheel. When I blew one of them, we found that the reason was out of alignment axles (both). Haven't had a blowout since aligning the axles. try it. You'll probably like it!
Old 11-01-2018, 12:55 PM   #17
I've had my Hercules SP2 'E' range tires since March and put 6000 miles on them so far.
They are looking good so far (took this since parking in storage last time):
Old 11-01-2018, 01:30 PM   #18
ditto, my 2018 goes in on the 12th for repairs, $1800 worth. We have a trip planned this weekend so we get to take it all beat up. I went with maxis tires because I have had good luck with them in the past. Dynamic Tire has the power king are looking into why they blew to see if they cover it. They are supposed to be giving me a 125 per tire as a goodwill gesture but I will believe that when I see it.
2017 Wildcat 327RE
2005 Chevy Silverado
2016 Nights camped in wildcat(14) didn't count previous trailer
2017 Nights camped (44)
2018 Nights camped (29) that's too low. Must work on it.
maskins is offline   Reply With Quote
Old 11-02-2018, 01:06 PM   #19
wde
Life long camper
wde's Avatar
Dynamic Tire scam
I tried to deal with Dynamic Tire for my problem.
Total waste of time.
Had to go through about three levels of phone tag to finally get in touch with them and then the claim was denied after they did their "due diligence" to quote the letter I received.
Old 11-02-2018, 01:39 PM   #20
I'm not expecting much, but I'm at least going to try to hold them to their "goodwill gesture."
2017 Wildcat 327RE
cat, tire, tires, wildcat
