Old 05-01-2015, 10:02 AM   #1
fresh water tank
Filled fresh water tank to get ready to leave today and its falling out of the bottom of camper. It tored the black lining almost all the way off. Just passed our one year ownership and it might not be warranted. HELP
bevsattva is offline   Reply With Quote
Old 05-01-2015, 10:13 AM   #2
Jerry01's Avatar
Sorry to hear of your problems. Can you actually see where it is leaking from? Is it a crack in the tank itself or is the fill hose leaking(this happened to me)? If you are just past your warranty, FR still might be willing to help out. If the crack, or leak is somewhere toward to top of the tank, then you would still have some water for your trip. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 05-01-2015, 10:20 AM   #3
Is it the tank falling out the bottom or water leaking? To me it reads that tank is falling out the bottom.
Pipeman is offline   Reply With Quote
Old 05-01-2015, 10:24 AM   #4
The tank is not leaking it is falling out of the bracket and the bracket is bent. the dealership says drive it out so they can look at it. Well we would have to rig it up just to drive it out because it could fall out.
Old 05-01-2015, 10:27 AM   #5
Ford Idaho's Avatar
Dump the water in it before you drive in.
Dealer can add all the water needed after you get there.
Old 05-01-2015, 10:36 AM   #6
Boss Ox & Drovergirl
oxcamper's Avatar
Our black tank slipped out of the "cradle" and had to have it repaired. The tanks are secured by placing them on angle iron brackets and sometimes they will slip off if not secured well at the factory, especially if they have some weight in them and / or are moved. Our black discharge pipe had slipped out and we got an gosh awful smell till we figured out what was wrong.
You have to remove the belly covering and slip the tank back onto the brackets. Ours was done under warranty and the dealer applied additional stainless steel straps to secure it better.
Out of Warranty-- bummer, but they can fix it pretty easily.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-01-2015, 03:55 PM   #7
It's a damn shame that the manufacturer sends out crappy frames. Is it cutting corners? What a crock. I sure hope you are covered for this piece of crap. By the way, you are not the 1st one to have this problem. I wonder if the defect has been covered by Forest River for all the others who have had this problem?
Old 05-01-2015, 04:27 PM   #8
Jerry01's Avatar
Wow did I read that wrong! Jerry
Old 05-01-2015, 06:01 PM   #9
Learjet's Avatar
year and model? please!
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 05-02-2015, 10:54 AM   #10
Learjet's Avatar
crap!...just went look under my unit...not even two months old and only a couple of trips...and the fresh water tank brackets are loose.
Trying to decide if I should pull the front of the underbelly off and try to fix myself ...or go back to dealer.
Took this picture with my phone through a gap the sagging tank made in the underbelly, you can see the bracket not attached....very sad
-2015 Wildcat 317RL
fresh water, tank, water, water tank
