Old 03-14-2018, 03:37 PM   #1
Fresh water tank filling up.
I have a 2016 Wildcat and when connected to city water over time the fresh water tank fills up. I assume there is a check value that is leaking, can anyone tell me where this valve is?
kdowdy is offline   Reply With Quote
Old 03-14-2018, 03:42 PM   #2
fonzie's Avatar
Check valve is in water pump, read this thread on how to fix
check valve in water pump system
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-14-2018, 04:03 PM   #3
Fulltime family RVer
I had this issue. I bought a new trailer.
It sure fixed that problem!
ependydad is online now   Reply With Quote
Old 03-18-2018, 03:56 PM   #4
I have this issue too with my ‘16 Wildcat, although “over time” would be an exaggeration for me; more like “within an hour or two”! I’d rather use from the fresh tank and run the pump anyway since pressure is always weak when using city water connection. Speaking of, is there a PSI range or recommendation for the fresh water system on these newer Wildcats? I haven’t been able to find anything on it.
btf66509 is offline   Reply With Quote
Old 03-18-2018, 04:03 PM   #5
cavie's Avatar
50/60 lbs. on any system. Never run over 60 lbs on a PLEX system.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 03-18-2018, 04:06 PM   #6
Thanks cavie, I’ve been running 45-50, and using the pump when I shower. Otherwise it just dribbles out.
Old 03-18-2018, 04:22 PM   #7
Had this problem twice. Disconnect city water then run off your pump. Then turn off pump and reconnect to city water. This usually flips the check valve in the water pump and your back in business without water tank filling up. One time after several tries this did not solve problem and I had to get a new water pump.
jrmorris is offline   Reply With Quote
Old 03-18-2018, 04:24 PM   #8
cavie's Avatar
clean the screen with your hose connection. Unscrew the shower head and clean that screen. Remove the reducing washer while you're in there. Check the faucet aerators while you're at it.
Old 03-18-2018, 04:30 PM   #9
cavie's Avatar
Most water pumps in RV's are rebuildable.
Old 03-18-2018, 04:31 PM   #10
Yep, did all that, didn’t help much. Tried my dad’s aftermarket shower head, it’s definitely better but still not nearly as good as with the pump.
Old 03-18-2018, 04:45 PM   #11
cavie's Avatar
I only use my pump to winterize. I guess I should exercise it once in a while.
fresh water, tank, water, water tank
