Old 01-24-2013, 07:54 PM   #1
Furnace fan will not come on 2008 wildcat 30lsbs
Our furnace fan will not come after turning thermostat on. We can hear it make a noise in roof a/c and then a noise at furnace. Sounds like relays making noise but fan will not cut on. Any information anyone can share would be greatly appreciated . We are living in Rv full time and have been in it since July 2012 waiting patiently till our new house is completed. I have been scouring the net since last Sunday and have got no where. Think I will have to pull furnace out but that should be easy beings forest river only put one cabinet screw in housing to hold outer shell of furnace to floor! Lol! Thanks Jason and Letty
yazookid1987 is offline   Reply With Quote
Old 01-24-2013, 08:10 PM   #2
caper's Avatar
If you have an air compressor, try blowing air into exhaust vent. You are trying to get the fan to turn. It might be that you have a dead spot on the fan motor. We had the same problem and had to install new brushes for the fan motor. We also had the comm. turned down at the same time.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-24-2013, 08:18 PM   #3
Ok will give that a try thanks! Comm. turned down at same time? What are u referring to?
Old 01-24-2013, 08:21 PM   #4
Thanks will give that a try! What do u mean by saying u had the comm. turned down at same time? I assume you pulled the furnace out or did u slide it out of the housing?
Old 01-24-2013, 08:38 PM   #5
caper's Avatar
The comm. is the commutator of the motor. Pulled the furnace had the motor reworked at a repair shop that repairs car starters.
Terry and Janet
2007 Ford F150
Old 01-25-2013, 09:54 AM   #6
Oh ok thanks for the info!
fan
