Old 08-09-2017, 09:18 PM   #1
twohand's Avatar
Furnace runs once, then won't restart
Our furnace runs once, then won't automatically restart after the temp drops below the set point. I have to turn the unit off at the thermostat, then turn it back on to get it to run. The A/C works fine. Any ideas?
FROG IL-0076-090
2016 Wildcat 323RBX, 1992 Excel Legacy "guest house"
98 Honda Shadow ACE, 78 Honda CB400A Hondamatic
Nights camped: ‘16 - 24, ‘17 -33, ‘18 - 27, ‘19 - 27
twohand is offline   Reply With Quote
Old 08-09-2017, 11:04 PM   #2
My first guess would be the thermostat.
If you have a stock mechanical t-stat, do yourself a favor and get a digital Honeywell from Walmart. Install is easy and it works much better than OEM one.
If new digital thermostat doesn't fix it, check the control board on the heater. Clean out any debris, check connections, and cleaning contacts on the control board.
Skyliner is offline   Reply With Quote
Old 08-10-2017, 09:15 AM   #3
twohand's Avatar
The t-stat is the original digital hockey puck Dometic that came with our 2016 Wildcat 323RBX.
FROG IL-0076-090
Old 08-10-2017, 09:32 AM   #4
We had an older Jayco that acted the same. Run once and wouldn't relight until the power was cycled to the furnace. Had to replace the control board. Bought a Dinosaur board and never had another issue.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 08-10-2017, 02:46 PM   #5
John Schaefer
Johnjschaeferjr's Avatar
Same Furnace Problem
I've had my Coachman Freelander for 3 years. First two years the Furnace did same thing. Also there were times that it wouldn't start at all. Multiple trips to CW and each time they returned it but did not fix it. Finally one of the techs worked with Dometic and got new board. Since replacement Furnace works well. Same sad story for the hot water heater. Dometic products are very poor and cause much grief in RV community.
Two major trips this year have gone well. No problems. Knock on wood!
Jack
28' Coachman Freelander MH
John Schaefer
2015 Coachman Freelander
VW New Beetle
Johnjschaeferjr is offline   Reply With Quote
Old 08-10-2017, 03:42 PM   #6
twohand's Avatar
Jack
I've had my furnace "repaired" and/or "thoroughly checked out" 3 times now, not including the pre-possession "complete check of all systems, plumbing, mechanical and electrical" by the dealer. Still doesn't work. I could by a house for what I paid for this FW and have fewer problems than what I've had with this FRW.
FROG IL-0076-090
Old 09-30-2017, 03:45 PM   #7
twohand's Avatar
Swapped out the thermostat yesterday. Still acts stupid. Has to be the control board. Dealership calling me on Monday to discuss. Got down to 42 here last night, so the space heaters were working overtime.
FROG IL-0076-090
Old 09-30-2017, 04:32 PM   #8
TimVWulp's Avatar
had the same problem last fall dealer replaced the control board. if you have to pay for it ask for a dinosaur brand board replacement.
Hope This Helps Tim
TimVWulp is offline   Reply With Quote
Old 09-30-2017, 06:50 PM   #9
twohand's Avatar
Hope This Helps Tim
Dealer is paying or I won't be buying my RiverStone from them.
FROG IL-0076-090
Old 09-30-2017, 07:47 PM   #10
My Roo 19 had the cheap Suburban analog T-stat. Same issue as you: furnace would start once, then never again unless I turned it off and back on at the T-stat. Replaced it with a Honeywell digital and never had another problem.
2011 Traverse LT, 3.6L, FWD
Old 09-30-2017, 10:48 PM   #11
twohand's Avatar
Dealer gave me a thermostat to try. Same Dometic model as the original. I questioned why they thought this was a good idea, but they assured me it was a good one. Now it's back in their court. Once it's working, I will say goodbye to the crappy Dometic and get a real one.
FROG IL-0076-090
Old 10-08-2017, 11:34 PM   #12
twohand's Avatar
After all the attempts they finally took my advice and replaced the control board. Guess what? It works like a charm now. Sheesh.
FROG IL-0076-090
Old 10-09-2017, 12:20 AM   #13
TimVWulp's Avatar
Glad to hear that it is fixed. Thank you for letting us know what the fix was.
Tim
Old 10-09-2017, 09:32 AM   #14
jeff64's Avatar
I had the same deal going on an Atwood furnasty in my old Jayco. CW said it was a board and sail switch. They took their own sweet time getting it not fixed. After six weeks in May, I went into it myself. After I bought the board and verified the sail switch was ok , replaced it and it still didn't work,( to say it is a PIA is a gross understatement).
I replaced the igniter. That stupid thing sends a flame presence signal back through the same wire to the board and has to have a good ground path to the chassis mount. IMHO I believe the integrity of that ground path on the igniter mount must play a significant role to the flame presence feature that may have less importance where the high voltage spark ignition is concerned and can jump it.
You can find manuals(.pdf) for these Atwoods and Suburban units online. Look at the troubleshooting and circuit diagrams( ignitor) you will see one wire going to igniter and a ground symbol. It gets some degree of corrosion from the heat path. My suggestion would be demount it ,wire brush the ground path and reinstall.
I had similar issues this year with the Suburban WH this year where it made a helluva bang lighting up on propane. Common consensus said "debris in the burner tube" and I couldn't see any evidence of it. I cleaned, re-grounded and checked the set on the igniter and problem solved. Just my 2 cents FWIW
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
furnace
