Old 05-25-2016, 11:02 AM   #21
That's the problem nothing consistent. It's not on my pin or battery connect because I redid that stuff already. FR wiring was terrible so I redid it all. I suspect it's jammed in the back wall somewhere I just can't see...frustrating
2016 Wildcat 312BHX
2015 Silverado 3500HD
sugarjohnson is offline   Reply With Quote
Old 05-25-2016, 03:19 PM   #22
Originally Posted by TGR View Post
My Wildcat 5th wheel came with the rearview camera connected to the battery disconnect switch. An inline fuse holder was connected to the cutoff switch and then on to the camera. I inserted a 12-volt switch in series with this line so I can turn off my camera when not needed.
Obviously, our trailers are wired differently but perhaps a wire with an inline fuse is connected close to the trailerís 7-way plug and runs back to the camera.
I would trace back a short distance from pin 3 of the trailerís 7-way plug and look for a connection and fuse holder for the camera. It might be just a blown fuse that is the problem.
Yup what he said. My buddy's Wildcat was same way fuse was behind panel holding disconnect.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 05-25-2016, 05:48 PM   #23
Well you guys may be partially right. I found the fuse you mentioned behind docking station and sure enough its blown. Problem is put a new one in and still no power. This leads me to believe wherever the problem is maybe it caused the short and blown fuse. Back to the start!
2016 Wildcat 312BHX
Old 05-25-2016, 06:29 PM   #24
Learjet's Avatar
Originally Posted by BandJCarm View Post
I hold the door for everyone.
Furrion makes (I believe) two separate cameras.......a Backup Camera, and an Observation Camera.
Last time I checked, both use same camera...different receivers/displays.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 05-26-2016, 07:16 AM   #25
Blog: RVroadtripper.com
hbillsmith's Avatar
Not true. Model 12 is backup and Model 48 is Observation. FOrest River installs 12's and calls them Observation. Furrion will trade. See furrion.com for more detail.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-26-2016, 07:59 AM   #26
Learjet's Avatar
That is where i saw the camera part, or transmitter, is the same part number for both.
-2015 Wildcat 317RL
Old 06-02-2016, 11:32 AM   #27
Well the camera issue is solved. Dealer removed existing power wire which was shorted against aluminum frame and ran new power from running lights. Camera was also fried in the process so new camera.
There was some mention of the 5 amp fuse behind the docking station being tied to some cameras. It does not appear it was on mine. Dealer can't figure out where this goes. Any thoughts? It's not for pump, lights jacks etc since all of that is in basement.
2016 Wildcat 312BHX
Old 06-03-2016, 11:42 AM   #28
where do you find info about them trading? I would love to have a better camera that doesn't freeze up..
rcrupper is offline   Reply With Quote
Old 06-03-2016, 08:43 PM   #29
FR got back to me and confirmed that indeed the 12v 5 Amp inline fuse coming off the batter disconnect was indeed originally wired for backup camera. Irrelevant for me now that it is rewired but hopefully this helps someone else.
2016 Wildcat 312BHX
