Old 06-01-2017, 05:44 PM   #1
SeventyGTX's Avatar
Garden room windows
Our Wildcat has the Garden Room with three long windows and two on the end of the slide. Is there a good dry lube for those? Three of the five are REALLY hard to pull up to open, and feel like they jam up a bit when going up and down with them. I didn't really want to use any wet lube as it will attract dust and dirt. Any advice?
2016 Wildcat Maxx 262RGX
2016 Ram 2500 Laramie Longhorn 4x4 Cummins 6.7 CCSB Factory Auto-leveling and 5th Wheel Prep w/B&W ball kit, Andersen Ultimate
https://www.forestriverforums.com/attachments/signaturepics/sigpic98816_1.gif
SeventyGTX is offline   Reply With Quote
Old 06-01-2017, 05:52 PM   #2
NMWildcat's Avatar
I use this dry lube on our windows, slides, and locks, as I can find it anywhere: https://www.wd40specialist.com/products/dry-lube/
303 also makes a similar product.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-01-2017, 05:59 PM   #3
SeventyGTX's Avatar
Wow, thanks! I had no idea WD40 made a dry lube. I will give it a try.
Old 06-01-2017, 08:22 PM   #4
cavie's Avatar
West Marine has dry lube.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
roo, window
