Old 03-29-2012, 01:12 PM   #1
JAYCO Representative
Wildcat Chris's Avatar
Lightbulb Girard Tankless Water Heater
Here's some information from Girard on the optional tankless water heater system in use by Wildcat (our standard is a 10 gallon DSI gas/electric "quick recovery" water heater). I'm providing it here as extra information for Forest River Forum members who both have Wildcats and are looking at this option for their future Wildcat...
This info is directly from Girard:
GIRARD TANKLESS WATER HEATER END USER TESTING GUIDE
OPERATING & TESTING INSTRUCTIONS FOR END USER
The Girard Tankless Water Heater operates differently than tank water heaters.
There are procedures that need to be done for the Water Heater to perform properly. The same is true for a tank water heater, but it is less critical for the tank model. Remember, the Girard Tankless Water Heater is giving immediate HOT water as you need it also it has no recovery time and it is not storing a tank of pre-heated water.
The Girard Tankless Water Heater will heat incoming water approximately 40 to 60 degrees depending on the water flow rate. The typical shower temperature is between 98 – 104 degrees. As a comparison a hot tub is usually set between 103 – 106 degrees.
If necessary, to check for the proper temperature rise (inlet cold water temperature to outlet hot water temperature) it will be necessary to use a thermometer. Use a digital thermometer which provides immediate temperature readings. These are available at most discount/department stores in the kitchen utensil section. DON’T trust your hands for temperature tests since hands don’t feel heat like the rest of your body. Your installer should have performed the following:
OPERATING PROCEDURE
  • Purge all of the air from all Cold and Hot water lines by opening up the faucets. Kitchen, bathroom sink, showers, toilet, outside shower/water faucets and washing machine water lines if applicable. Be sure to turn OFF the outside shower faucet rather than just closing the shower head OFF button. This procedure should be performed whenever the water lines have been emptied/drained.
  • Go to the kitchen faucet and turn on the COLD water and note the temperature (allow sufficient time to get a valid reading). Let the water run into a cup and place the thermometer probe into the cup. Turn OFF the COLD water faucet and make a note of the COLD water temperature.
  • Turn the Water Heater ON – ON/OFF Switch is located outside in the Water Heater compartment. You can leave this switch ON all season since it only draws power when there is a demand for HOT water.
  • Set the Mode Switch to AUTO or HIGH.
  • At the kitchen sink, turn the HOT water faucet ON to about a medium water flow. Allow sufficient time for the HOT water to travel from the Water Heater to the faucet.
  • Check the HOT water temperature. Let the water run into a cup and insert the thermometer probe into the cup. At the medium water flow rate you should see approximately a 40+ degree temperature rise. You can gradually adjust the HOT water flow (a very small adjustment) to adjust the HOT water temperature; don’t look at the knob/lever but at the actual water flow. Allow sufficient time for the water to travel from the Water Heater to the faucet after each adjustment. Try to achieve a temperature up around 110 – 115 degrees. Let it run for a few minutes to confirm that the temperature is maintaining.
  • The Water Heater will provide approximately a 40 – 60 degree temperature rise (from inlet water temperature) depending on the Hot water flow rate. So, if the inlet water temperature is 55 degrees, you should have Hot Water from approximately 95 degrees to 115 degrees (depending on the Hot Water flow). NOTE: If the water temperature starts cycling from Hot to Cold and then back to Hot it means the Water Heater is limiting so increase the hot water flow. The Water Heater has an Emergency Cut Off sensor that turns the burner off at approximately 122 degrees to prevent scalding. If still limiting set Mode Switch to LOW.
  • If you achieve the various temperatures at the kitchen sink move to the shower and perform the same test. Note – Certain Shower heads/fixtures may vary the results due to water flow/pressure. Contact your Girard Dealer or Service Center if you can’t achieve the proper temperatures.
  • Since the Girard Tankless Water Heater does not have a tank it does not need to pre-heat and store water to 130 to 140 degrees. Tank water heaters must heat the water hotter since they are trying to make 6, 10 or 12 gallons of Hot water last longer (so you can mix it with cold water to achieve the proper hot water temperature) and allow the end user a few minutes of Useable Hot Water temperatures. With the Girard Tankless Water Heater it is not necessary to “super-heat” the water since you do not have to mix Hot water with Cold water to achieve the Useable Hot water temperatures; it will provide all the Useable Hot water you need and will only draw power (to make that Hot water) when there is a demand for Hot Water.
Wildcat Chris is offline   Reply With Quote
Old 06-05-2012, 02:45 PM   #2
Old 07-19-2012, 10:52 PM   #3
Girard Tankless water heater
I can tell you....this is our second season with a Girard tankless hot water heater in our 322Rk and if my wife could/would operate a wrench it would be in the garbage......It takes a long time for the hot water to reach the bathroom sink and it seems to have a mind of its own when it comes to temperature plus I think we waste more water then we did propane on our older trailer with a tank. I have printed your instructions and will give it a try.
2005 Dodge 2500, 5.9 L, 1975 TR6, 2011 322RK Wildcat, 1964 Wife
john lennon is offline   Reply With Quote
Old 07-20-2012, 03:04 PM   #4
Please call Girard's Tech Support Department if you need help:
866-559-1221
Mon - Fri, 7:30AM to 4:00PM.
Old 07-21-2012, 08:50 PM   #5
So far we love the Girard, no more waiting for hot water between showers! :-)
Now if I can just figure out why the furnace is not starting, here a click but no fan and no heat.
smethers is offline   Reply With Quote
Old 07-21-2012, 09:21 PM   #6
troyt's Avatar
I don't have a Wildcat but I might be interested. Thanks for peaking my interest. 3 to 4 adults taking quick showers and waiting for the water heater to keep up is somewhat of a pain.
2006 Dodge 2500 Crew Cab 5.9L Cummins 4X4 200k mls
2010 Forest River Flagstaff 831QBSS - Equal-i-zer Hitch
2011 HD FatboyLo & 2000 Honda Shadow 1100
Nights Camped 2010 (7), 2011 (15), 2012 (35) 2013 (40) 2014 (22) 2015 (12) 2016 (10) 2017 (?)
troyt is offline   Reply With Quote
extralite, sterling, tankless, wildcat, water heater
