Old 07-16-2016, 02:11 PM   #21
AJ 72's Avatar
Update.
I got the sail switch replaced.
We went on a camping trip. The water heater quite working the first day.
I brought it back to them after the trip. And they replaced the pressure valve.
I tested it after and I had hot water at both taps & the shower.
Went on another camping trip and Again the hot water quite working after 1 day!!!
Now the shop is telling me they can't fix the unit without removing a safety switch. Which they won't do.
They recommend switching to a regular hot water tank.
Not really what I wanted to hear on a 2012 trailer.
Advice appreciated.
2013 Forrest River Wildcat 293 REX Extralite
2007.5 GMC 2500HD SLT Duramax (modded)
AJ 72 is offline   Reply With Quote
Old 07-16-2016, 02:25 PM   #22
BandJCarm's Avatar
I have tankless, and I'm getting it replaced with a conventional....and mine is a 2017.
Others love their tankless.
I know, that's plenty vague, but I prefer dependable and ending hot water to undependable and occasionally unending hot water. All I need hot water for in an RV is to shower (I could heat water in microwave to wash dishes if necessary, just two of us and we use chinette stuff mostly), so 10/12 gallon conventional that is dependable is all I need.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-16-2016, 02:30 PM   #23
NMWildcat's Avatar
[QUOTE
Advice appreciated.[/QUOTE]
Something doesn't sound right in what the dealer is telling you. Sounds like they don't know how to fix it and it would be easier for them to put in something they do know. If girrard won't get back to you I would try a FR factory rep or at least another dealer.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-16-2016, 02:31 PM   #24
AJ 72's Avatar
Yeah, cold showers suck! Especially when have to make your kids take ice cold showers.
Old 07-16-2016, 02:38 PM   #25
AJ 72's Avatar
NMWildcat
AJ 72
I don't have much confidence in the dealer that it's at. I've already got over $400 dollars into this and still have a broken water heater!!!
I guess I have to decide if I keep throwing money at this. Or just scrap it?
Old 07-16-2016, 03:24 PM   #26
NMWildcat's Avatar
Ouch... It didn't register that you were out of pocket. I would definitely start bombarding Girard. Maybe they can help the dealer techs or give you another option. I have also found if I take a problem to another dealer/shop and say so-and-so couldn't fix it maybe you can, that it's amazing what can be fixed. And I would be asking the dealer for some help on your $400 that didn't fix anything. Good luck!!
Old 07-19-2016, 06:51 PM   #27
AJ 72's Avatar
Ok. Finally getting somewhere on this.
I have learned that our water heater IS covered under First Canadian Warranty.
And I also finally talked to someone at Girard.
They recommended swapping the first generation unit we have with a second generation unit IF warranty agrees to pay for it.
I'm also looking into seeing if I can pay the difference and going with the third and current generation of Girard water heater.
I'll update once something gets resolved.
Old 07-19-2016, 07:19 PM   #28
NMWildcat's Avatar
Glad to hear you are finally getting some help with this!!! Hope this means you will get some $$$ back from the dealer
Old 07-19-2016, 07:35 PM   #29
VinceU's Avatar
Atwood markets a similar continuous hot water heater with much less problems.
Old 07-19-2016, 08:13 PM   #30
AJ 72's Avatar
Thanks. They will cover some of my previous costs. But they don't want to pay for the sail switch or the removal & installation of it. Because in their eyes it wasn't necessary because it didn't fix the problem.
I'm still working on getting them to cover that....
heater, tank, tankless, water, water heater
