Old 06-14-2016, 11:30 PM   #1
AJ 72's Avatar
Girard tankless water heater problems
Hello,
Can anyone give me advice on diagnosing the cause of my tankless water heater not working?
I really don't know much about them?
It's a first generation Girard Tankless water heater. GSWH-1
It would light and then go out right away.
Maybe a pressure sensor fault?
Now it won't light at all.
Cold showers suck....
I'm using the trailer in a couple of weeks, I need to get this fixed ASAP.
Thanks.
2013 Forrest River Wildcat 293 REX Extralite
2007.5 GMC 2500HD SLT Duramax (modded)
AJ 72 is offline   Reply With Quote
Old 06-15-2016, 12:28 AM   #2
AJ 72's Avatar
My trailer is a 2012 Wildcat 293REX.
Old 06-15-2016, 12:44 AM   #3
Some guy in back...
I'd suggest you call the company in California in the morning. If you are nocturnal, maybe check their website for troubleshooting info.
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 06-15-2016, 01:11 AM   #4
AJ 72's Avatar
Thanks, I sent an email to Girards tech department. I just thought I'd see if anyone on here had similar problems.
Old 06-15-2016, 06:01 AM   #5
CAT-RN's Avatar
Just call Girard. I had issues with mine early on. Their tech will talk you thru the problem. Very helpful & informed techs.
They will send you parts if need be. Also they are on West coast time.
Russell
CAT-RN is offline   Reply With Quote
Old 06-15-2016, 07:28 AM   #6
Girard Water Heater Issues
You may have already checked this out but here's a link to their website.
There are some troubleshooting guides in the owners manuals.
Home - Green Rv
Roorider is offline   Reply With Quote
Old 06-15-2016, 01:47 PM   #7
NMWildcat's Avatar
Russell
X2 - quickest way to get your problem solved.
Scott and Liz - Southern NM
Old 06-15-2016, 01:58 PM   #8
muddyrode's Avatar
i had to repleace my freeze sensor as it was kind of doin the same and then the pressure sensor went bad since then it has work great and that was 2 years ago
girard customer service was great to work with
good luck
2012 wildcat sterling 32RL
2013 3500HD DRW Silverado Duramax
Remember slow and steady wins the race
muddyrode is offline   Reply With Quote
Old 06-15-2016, 07:26 PM   #9
ACE110's Avatar
I also had a lot of problems with my tankless WH. Finally managed to get it changed out for a new model, with the adjustable temperature control. Works reasonably well now. The techs are very helpful. However, if I was to get a new trailer not sure I would go with tankless.
2012 Forest River Wildcat 313RE
2012 GMC Sierra 2500 HD Duramax
Demco Hijacker 18K Autoslide Hitch
BAK Roll-X Tonneau Cover
ACE110 is offline   Reply With Quote
Old 06-15-2016, 10:00 PM   #10
7 Year Class A RV'er
Kyle Johnston in support at Girard is very good to work with. It definitely sounds like a sensor issue. If it doesn't get the right signals it shuts off quickly.
2015 Legacy SR340 360RB
heater, tank, tankless, water, water heater
