Old 12-28-2015, 01:09 PM   #21
wwalker2984's Avatar
Oh and yes I have my batteries wired according to the second part of that drawing
wwalker2984 is offline   Reply With Quote
Old 01-04-2016, 04:32 PM   #22
Originally Posted by Kenny kustom View Post
I found this diagram for proper loading of the batteries. Looks about right. Attachment 96883
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
I am try to understand something here in your diagram aren't all the batteries wired the same? In both diagrams they are wired the same, positive to positive and negative to negative, I don't think it matters what post you come off of, as long as it's a positive post or a negative post
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 01-04-2016, 04:37 PM   #23
Kenny kustom's Avatar
It does matter, not a lot..
But for a " balanced load", that's the way it should be wired.
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 01-04-2016, 05:08 PM   #24
Originally Posted by Karl4Cat View Post
Depends on size Bob. Lifeline does lots of options for AGM's. I have the 4CT's currently and considered adding a second pair in the basement. However, I never seem to dry camp long enough to run them down. Solar and genset seem to top them up as needed. On my last rig I had more room so I had one of the 8D 12V's. Almost 160# for the one! There was no removing that big fella for the off season... Here is there page with all your options.
Lifeline Batteries - Marine & RV Deep Cycle Batteries
I always thought the hot setup would be six 2V's putting out 900 AH!
I can't figure out something, how many volts would you have with six 2 volt batteries?
Old 01-04-2016, 05:13 PM   #25
2016 Sabre 36QBOK
I just have a hard time trying to figure out how a bank of batteries knows what post you hook up too.
Old 01-04-2016, 05:42 PM   #26
Left Coast
It's called resistance...
Old 01-04-2016, 05:50 PM   #27
I have looked at the 12 volt side of life and I just don't see it. My batteries have been hooked up both ways and I can't see a difference
Old 01-04-2016, 05:58 PM   #28
Left Coast
Run the battery's down.....no charger on......stick a charger on, take a volt meter right away, test voltage with batteries charg'n , on lead battery, then 2nd one
Old 01-04-2016, 06:01 PM   #29
If you wire say
1-2-3-4.
Then hook leads to batt 4. It will always have the most load, and the most charge.
It's really up to you how you would like to wire it.
Our way, just works better.
But other ways work too!
2016 Sabre 36QBOK
Old 01-04-2016, 06:04 PM   #30
Left Coast
Thank you!
battery
