Old 05-20-2013, 02:17 PM   #11
Owner/Operator
RodeoGeorge's Avatar
Originally Posted by dona5779 View Post
If you already have a goose neck receiver installed on your truck just buy a B&W Companion 5th wheel hitch. Goes in and comes out with ease so you end up with the best of both worlds No warranties voided. IMHO Chris
I have the B&W FLAT BED Companion, and it's even easier to install and remove than the standard Companion.
I loosen ONE bolt (torqued to 40 ft-lbs) and pull it out. I believe the standard Companion has several bolts that must be loosened.
The Flat Bed version requires that you have a thick reinforced bed on which to sit the hitch.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 05-20-2013, 02:40 PM   #12
My Companion has three bolts to loosen before pulling out of gooseneck hitch receiver. Chris
dona5779 is offline   Reply With Quote
Old 05-20-2013, 03:13 PM   #13
Fulltime family RVer
Yep- 2 U-bolts (80 pound torque) and 1 draw-down bolt (40 pound torque).
I'll admit- I'm jealous of the flat bed companion's difference in installing and removing it.
Old 05-20-2013, 03:21 PM   #14
But it's still easier to return to a flat pick up bed compared to regular 5th wheel hitch styles. Since I use my truck for hauling feed and hay, I need all the space I can get. Chris
Old 05-20-2013, 03:30 PM   #15
I have no comparison, but I do love the ease of removing it.
Old 05-24-2013, 07:47 AM   #16
Thank you all very much. I appreciate the help.
2013 Wildcat 293REX
2010 Dodge 2500 TRX4
bfuqua99 is offline   Reply With Quote
