Old 05-18-2013, 09:22 AM   #1
Gooseneck adapter
I have a 2013 293REX. I am considering putting a gooseneck adapter on it, but I have read it could cause a problem on some fifth wheels. Is this the case for the new wildcats?
Thanks for any information.
2013 Wildcat 293REX
2010 Dodge 2500 TRX4
bfuqua99 is offline   Reply With Quote
Old 05-19-2013, 09:48 AM   #2
lindy's Avatar
Don't know about your unit BUT some mfrgs will VOID the warranties if a gooseneck adapter is used on their 5th wheel trls
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 05-19-2013, 10:42 AM   #3
John McClain's Avatar
I ran goosenecks for years on my flat bed trailers . I would not switch my 5th wheel over if you paid me to. My wife could never hook a goose neck up by herself. with the 5th wheel my daughters could hook and go in 5 min. Why are you thinking of switching over are you having problems with your hitch? How many 18 wheelers do you see with a goose neck. my 0.02
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 05-19-2013, 10:53 AM   #4
It puts a tremendous load on the pin box mount that the trailer was not designed to absorb. Wouldn't dream of it on an rv trailer.
Old 05-19-2013, 11:03 AM   #5
I think Reese has an adapter called the goosebox that one or more of the frame manufacturers have ok'd. But I would look into it to make sure before purchasing.
http://www.reeseprod.com/content/pro...ID=7390&part=0
Filthy Beast is offline   Reply With Quote
Old 05-19-2013, 11:52 AM   #6
The main two reasons are 1: I'm tired of having to remove the hitch when I need the use if my bed. 2: the noise when hitting bumps when towing. I can probably get rid of most of the noise by getting a better hitch.
2013 Wildcat 293REX
Old 05-19-2013, 11:53 AM   #7
I actually watched a video on the goosebox. It looks like a god concept. Thanks.
2013 Wildcat 293REX
Old 05-20-2013, 06:10 AM   #8
If you already have a goose neck receiver installed on your truck just buy a B&W Companion 5th wheel hitch. Goes in and comes out with ease so you end up with the best of both worlds No warranties voided. IMHO Chris
dona5779 is offline   Reply With Quote
Old 05-20-2013, 10:07 AM   #9
That is a great concept. I do not have a goose neck receiver in already. This looks like a good fix if I did.
2013 Wildcat 293REX
Old 05-20-2013, 02:01 PM   #10
This hitch system gives you the both types of pulling. I have it installed in my F-150, now I have bumper pull, goose neck and 5th wheel all in the same truck.
The gooseneck part of the system took me about 4 hours to install and the 5th wheel took about 20 minutes for set up then form there it's less then 5 minutes to reinstall. I bought the B&W system as it's built. I know there are other brands out there that are little cheaper but if I'm pulling my new trailer, I want the toughest hitch. Chris
